intake manifold gasket replacement question
Old Oct 10, 2009 | 07:05 PM
ZDRpewter01's Avatar
ZDRpewter01
Default intake manifold gasket replacement question
So I am in the process of doing this and notice that the middle intake ports are blocked off and the rear 2 are restricted by the gasket. Any reason behind this?? I just want to make sure I have the right gasket set. Thanks!
Old Oct 10, 2009 | 07:27 PM
tblt44's Avatar
tblt44
Is that your car in the avitar?
You posted this in the C4 section
Old Oct 10, 2009 | 07:39 PM
floridamale's Avatar
floridamale
If you are doing your 86, on a L98 water runs through the intake manifold front & rear the rear gaskets have restrictor plates with a small hole they are ment to be used that way. here is a photo of the right gasket.
Old Oct 11, 2009 | 02:38 AM
ZDRpewter01
Haha sorry ya it's on my '86 not my '01. Ya I was just making sure I had the right ones. Thanks!
Old Oct 11, 2009 | 03:35 AM
jeffp1167's Avatar
jeffp1167
the niddle would be blocked of if egr gases are drawn through a pipe on the exhaust manifold. If you don't have that pipe you need gaskets with the center port open.
To intake manifold gasket replacement question
