How to pull the tranny?
Old Oct 12, 2009 | 06:48 PM
JSki's Avatar
JSki
Default How to pull the tranny?
Alright you guys, I need one of you hardcore guys to tell me the best way to get the tranny out. I'm assuming it's going to be as involved as dropping the front cradle, but I hope I'm wrong. I would look it up in my FSM, but some one stole book 1 while I was staying at the hospital with my daughter. Any help is appreciated!
Old Oct 12, 2009 | 06:56 PM
TravisD's Avatar
TravisD
Manual or automatic?
Old Oct 12, 2009 | 07:26 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
Dropping the front cradle? This is the C4 section.
Old Oct 12, 2009 | 07:45 PM
Mark85Vett's Avatar
Mark85Vett
year??? Auto or stick??? 4+3??? 6 spd??? You have to help us out with a little info so we can help you!!!
Old Oct 12, 2009 | 08:33 PM
M. Schumacher's Avatar
M. Schumacher
I'm assuming this is the 95 lt1 auto?
As usual, you'll probably get some differing opinions on how to do this.
To start, remove the fluid level indicator. Unfasten or remove the bellows between the air filter and the throttle body. Undo the ASR box on the left inner fender and lay it out of the way. (see 1 below)
Get it up in the air - the higher the better. Then remove:
The two underbody braces (at the motor mounts)
The shift cable
The exhaust system up to the cats (see 2 below)
Drain the fluid (see 3 below)
Support the transmission - remove c-beam and driveshaft (mark position)
Allow the transmission tail to tip down some
The catalytic converters (see 4 below)
The starter
The inspection cover
The torque converter bolts (mark position)
The fill tube bolt and free the fill tube (see 5 below)
The cooler lines at the transmission
The electrical connectors to the transmission
If I haven't forgotten anything, it should be about ready to come out. Support the engine and remove the remaining bellhousing bolts. Drop it out.
Footnotes
1 - This step is to eliminate interference when tipping the engine back
2 - Unplug the O2 sensor. If you can break it loose, remove it.
3 - The fluid can be drained first by pumping it out the fill tube.
4 - Use heat to free stubborn nuts
5 - Don't try to completely remove the tube. Let it hang.
Old Oct 12, 2009 | 08:45 PM
tblt44's Avatar
tblt44
I will save this for my 95 auto.I have a worn bushing in the back of my transmission,no leak yet just watching it.
Why do you have to support the engine???
Old Oct 12, 2009 | 09:11 PM
aboatguy's Avatar
aboatguy
Because it will tilt back and hit the fire wall (good way to break oil sending units, composite valve covers etc
I use a long (36" half inch drive extension and a 1/2 to 3/8 adapter with a swivel socket IOT remove the bell housing bolts.
There's a couple of pics in this thread
http://forums.corvetteforum.com/c4-t...-in-today.html
Old Oct 13, 2009 | 12:13 PM
JSki's Avatar
JSki
Thanks for the input so far, it is an Auto. Sorry I forgot to put that, I am just a little flustered though. The owner before had a decent performance transmission in it and it has less than 10,000 miles on it so the fact that it took a dump on me is aggravating.
Old Oct 13, 2009 | 12:36 PM
383vett's Avatar
383vett
If the tailshaft bushing is worn, the tailshaft can be removed without removing the tranny.
Old Oct 13, 2009 | 01:36 PM
M. Schumacher
I know exactly how you feel.
My 96 was freshly rebuilt when I got it at 100k miles. It died at 110k. I took it out and rebuilt it myself. The guy that was there before me did good work, but he just didn't go far enough. He re-used a "sprag" bearing and it fell apart.
If you're handy with tools, the 4l60e is an easy transmission to work on. You don't need much in the way of specialized tools to do the job. There's a dvd video available that will guide you through the process, and there's plenty of help here if you get stuck.
Old Oct 13, 2009 | 02:12 PM
JSki's Avatar
JSki
Since I'm thinking of doing a complete rebuild while I have it out, anyone have any recommendations for the rebuild kit to use? I'm thinking of going with one of the Monster in a box kits, but I'm curious if it's worth the money.
Old Oct 13, 2009 | 02:16 PM
rickneworleansla's Avatar
rickneworleansla
http://forums.corvetteforum.com/c4-g...-kit-pics.html
http://www.700r4l60e.com
Old Oct 13, 2009 | 02:46 PM
JSki's Avatar
JSki
I was looking at this one
4L60E Mega Monster Transmission Complete Rebuild Kit: 1993-97
[Part# MG4L60E-BX97] $549.00
Click to enlarge
4L60E Mega Monster Complete Transmission Rebuild Kit
Order a "Monster-in-a-Box" and build your own Monster Transmission. Due to high demand, we are now offering complete Monster rebuild kits for our most popular transmissions. Build it yourself and save! Our Monster Rebuild Kits are moderately priced and offer an exceptional value for the performance minded street enthusiast. Everything is included that we use in our transmission, see the list below for details.
Mega Monster Rebuild Kit Includes:
▪ Paper Gaskets
▪ O-Rings
▪ Lip Seals
▪ (1) Molded Piston
▪ Sealing Rings
▪ 4L60E Corvette 2nd Gear Servo
▪ Friction Clutch Plates
▪ Steel Plates
▪ 3-4 Alto Kolene Steel Kit
▪ 3-4 Alto Red Eagle Clutch Kit
▪ 4L60E Filter
▪ 4L60E Heavy Duty Kevlar Band
▪ Teflon Pump Bushing
▪ Delco Front Seal Retainer Clip
▪ 4L60E Superior Shift Reprogramming Kit
▪ Hardened Pump Rings
▪ 4L60E 10 Vane Rotor Gear
▪ 4L60E 10 Vane Rotor Guide
▪ 4L60E 10 Vane High Rev Kit
▪ Heavy Duty "Beast" Sun Shell
▪ Heavy Duty 29 Element Sprag
▪ Heavy Duty Wide Rear Sprag
▪ New Electronics Included
▪ 1-2 Shift Solenoid
▪ 2-3 Shift Solenoid
▪ Manifold Switch
▪ EPC Motor
▪ 3-2 Solenoid
▪ PWM Solenoid
▪ TCC Solenoid with Harness
▪ Monster Transmission Decals
▪ Fast Free Shipping!
LINK
Old Oct 13, 2009 | 03:02 PM
M. Schumacher
I also used Dana (the above link) for the rebuild kit, however I went with the street and strip version. If you go this way select the dual element sprag and get the transgo separator plate, which is an extra. I also replaced the pressure switch which does not come with the kit.
Dana is an easy guy to deal with and he puts a good kit together. He's not a ball of fire (speedwise), however, and it would be good to do your research and have a solid idea of what you need before placing the order.
Old Oct 13, 2009 | 03:09 PM
JSki's Avatar
JSki
I have two more questions. In my 95 Vette is it a 1 or 2 pc bellhousing and has anyone experience having a sunshell come apart on it?
According to my Chevy dealer I use, the sun shell on these were a weak point because they were tac-welded together so too much power to it would cause it to snap loose and the problem that arises is the same as what I am experiencing:
Transmission tries to engage, but won't move and there is no binding when shifting through the gears.
Old Oct 13, 2009 | 03:10 PM
M. Schumacher
There's a lot of stuff missing from that kit, as listed. You should replace ALL of the bushings and ALL of the torrington bearings. I didn't need to replace any of the solenoids. They can be tested.
Old Oct 13, 2009 | 03:12 PM
rickneworleansla
LINK
I would call them up. Ask what cars their 4L60e transmissions are running in, how long are they holding up, ET's, power levels, etc. Also ask for some additional info on the parts in the kit and the short commings of the stock GM 4L60e. Then call Dana at Probuilt and ask the same questions. I think I know which one you'll choose.
To How to pull the tranny?
M. Schumacher
One piece. The sunshell breaks, or strips out. When that happens you will lose reverse, second, and fourth.
Old Oct 13, 2009 | 03:31 PM
wolverine1967's Avatar
wolverine1967
You will also need a 24" extension for your socket wrench with a 14mm swivel socket (not a swivel with socket attached) to get the bolts off the housing to engine area.
I just did mine and it was quite the job for a first timer. Good luck with yours. Ask me any questions you'd like. Mine was a 95 4L60E too.
And oh yeah....pictures, pictures, pictures before you touch ANYTHING.
Old Oct 13, 2009 | 04:00 PM
JSki's Avatar
JSki
So if it was the sunshell I could theoretically drop it into low gear and the tranny would still allow the car to move, correct?
