Clutch Questions
Old Oct 14, 2009 | 02:52 PM
89vette's Avatar
89vette
Default Clutch Questions
I've been away from this forum for a while and hardly every drive my Vette. I need a new clutch. I'm currently running a SPEC steel flywheel and pressure plate (although I think Spec supplied the stock Valeo PP) and a McLeod dual friction sprung disk. The clutch is toast after only a few hundred miles. It can't hold the power and you have to slip it a little to get it going after the solid roller and single plane intake install. I'm also running the stock 3.33 rear gears and I think I could use a lower gear to help.
Who makes a nice clutch and flywheel setup for these cars these days?
Jason
Old Oct 14, 2009 | 03:07 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
If the clutch only lasted a few hundred miles, I say something was wrong with it. Are you just drag racing it? What kind of HP does it have?
Old Oct 14, 2009 | 03:24 PM
89vette's Avatar
89vette
No drag racing. I have to slip it to get the car going and rev the engine. It smells of burnt clutch every time I start out hard. I never had it dynoed so I don't know how much HP it has.
To Clutch Questions
