rear end
Old Oct 16, 2009 | 06:45 AM
sceptor98's Avatar
sceptor98
Default rear end
Does anyone know what type of rear end axle an 86 has stock? Has anyone had to change thier rear end due to higher torque and hp from thier engine? and at what rating?
Old Oct 16, 2009 | 07:45 AM
aminnich's Avatar
aminnich
auto trans is a D36, manual is D44. The D36 is the 'weak' rear.
Old Oct 16, 2009 | 09:00 AM
sceptor98's Avatar
sceptor98
Thanks!!! Now with that said what would be the max/recommended hp and torque i can run on a 2.59:1 ratio?
Old Oct 16, 2009 | 09:32 AM
aminnich's Avatar
aminnich
First off the 2.59 ratio is not good for any kind of performance other than fuel economy when cruising. Then HP and torque will vary somewhat due to tire traction (drag radials vs street tires) so an exact answer is impossible. A very general response is that the D36 with a stock Auto trans is safe to 400 hp, maybe slightly more.
Old Oct 16, 2009 | 10:07 AM
rodj's Avatar
rodj
http://forums.corvetteforum.com/c4-t...ic-limits.html
Old Oct 16, 2009 | 11:06 AM
sceptor98's Avatar
sceptor98
thanks guys!!!
To rear end
