What code did you get, and after that, did you check the diagnostics links from Agent 86?
LOL Happens to me all the time...
I got code 33 and 45. My plans are: clean the throttle body and MAF sensor, replace the MAF relays, and change the fuel filter (I only have 4K on current one but it can't hurt...). Also run a check on the fuel pump circuit.
Yes, I checked the link. Very interesting and informative!
I have limited time so I'm hitting the simple stuff first.
Cleaned throttle body and MAF with CRC products. Replaced both MAF relays, air duct (old one was cracked), and PCV valve. Cleared codes and took it for a spin...
