Generic chip for '89 PROM?
Old Oct 18, 2009 | 02:56 PM
tonymax2's Avatar
tonymax2
Default Generic chip for '89 PROM?
Anyone out there know what generic EPROM or EEPROM will replace the factory PROM chip in a late build '89 (SN 19500). ECM is 88999194, a replacement for the original, I guess.
Old Oct 18, 2009 | 05:09 PM
rodj's Avatar
rodj
Auto or manual?
Old Oct 18, 2009 | 05:53 PM
gbrtng's Avatar
gbrtng
Originally Posted by rodj
Auto or manual?
Are you trying to fix a problem, or do you just want a spare?
Old Oct 18, 2009 | 09:49 PM
tonymax2's Avatar
tonymax2
Auto or manual?
Doesn't really matter, it's the code IN the chip that is different, but mines an auto, 3.07:1 axle, C68 for the record
Old Oct 18, 2009 | 09:52 PM
tonymax2's Avatar
tonymax2
My car has a Hypertech Thermo chip in it and I figure sooner or later I'll probably get into burning my own chip. At present I may have a chance to get a programmer for free so I thought I'd better get some info.
Old Oct 20, 2009 | 09:33 PM
tonymax2's Avatar
tonymax2
ttt
Old Oct 20, 2009 | 10:15 PM
rodj's Avatar
rodj
Auto memcal has programming fot convertor lockup which man doesn't ; as well as other things
Old Oct 24, 2009 | 12:11 AM
tonymax2's Avatar
tonymax2
ttt
Old Oct 24, 2009 | 01:19 AM
WVZR-1's Avatar
WVZR-1
Here is a link to a calibration identifier:
http://tis2web.service.gm.com/tis2web
Once you enter your VIN I believe it will supply calibration codes in a "release sequence". I'm quite sure there are reasons to want to use particular "calibrations" for a base to build from.
Most information you're looking for are already sorted and have been evaluated in the C4 "scan & tune" section.
Old Oct 24, 2009 | 02:02 PM
tonymax2's Avatar
tonymax2
Thanks for the info, Dave, but I'm not that far into the guts of these systems yet. I prowled that GM site and found a couple of descriptions that seem to match my car, but don't understand what the PN and CVN are unless they're the actual GM PN for the PROM chip. I also don't understand what the "Controller" number is since it doesn't match any of the three ECM PN's I've seen listed for the '89 (1227165, 16198259 & my 88999194).
Since none of the "Controller" number options available have any PN's which show a "CVN" number, I couldn't get into the CVN look-up to see what that might tell me. It's all Greek at the moment.
The original intent of this thread was to verify what generic chip is used in the '89 ECM so I can verify if the programmer I can get for free will burn that chip. So far I've heard a 27c128, 27c256 or 29c256 chip will substitute.
If you care to enlighten me on the meanings of that GM sites terminology I'd be grateful, but I'll understand if you pass.
Old Oct 24, 2009 | 03:16 PM
89onlyZ51's Avatar
89onlyZ51
The 27c128 is the stock chip. A 27c256 will also work - it just reads the program from the second 128k on the chip. The programmer can offset it for you, or do like I do and just add the bin to itself with a DOS command.
I use 29c256 chips because they're rewritable without having to use a UV eraser. I bet your hypertech chip is rewritable, too.
Old Oct 26, 2009 | 11:52 PM
tonymax2's Avatar
tonymax2
Thanks for the info, Tom. From what I'd read on the CF, I was getting the idea that that was the chip (s). I know this programmer will handle those chips, now all I have to do is find the software for it at work. The techs and engineers that used it years ago are gone, their computers have been shuffled off to IT heaven somewhere and the OEM obsoleted it about 3 years ago.I'm a sucker for salvaging old hardware but we still have 2 others I could use if that doesn't pan out but not as conveniently. By the way, is there literature out there somewhere that details the actual data and how it's used in the control program (which I assume is hard loaded into whatever microprocessor or ROM is in there) Thanks again
Old Oct 27, 2009 | 01:16 AM
89onlyZ51's Avatar
89onlyZ51
Read the stickies at the top of here:
http://www.thirdgen.org/techboard/diy-prom/
This will tell you everything you need to know to start burning chips. What model programmer are you trying to use?
Old Oct 27, 2009 | 07:46 PM
tonymax2's Avatar
tonymax2
It's a BP Microsystems EP-1, one of the first on the market I take it. My investigations at work today haven't unearthed any more data or such on it. Some of the electronic guys were telling me they think the main computer that the previous engineers used with it was a 286 laptop.That gives you an idea of how long ago it has been. The IT guy that might still have that laptop on his junk rack won't be back till next Tue, so I have to wait. Boy, do I hate waiting. I may have to switch to reviving the next oldest obsolete unit. If worst comes to worst, I could probably use their newest unit but would take second or third fiddle to the engineers and e-techs. I'll prowl that site and see what I can learn. It's been 20 years since I burned chips-Mac 512 to Mac Plus as I remember. Don't ask where I got the +chips to copy!
Old Oct 27, 2009 | 07:59 PM
M.J.L.'s Avatar
M.J.L.
St. Jude Donor '10-'11
Garbage. Custom chips only!
Old Oct 28, 2009 | 12:46 AM
89onlyZ51's Avatar
89onlyZ51
Email tech@bpmicro.com. Someone will give you the old DOS software and you'll be on your way. Even though they don't officially support it, unofficially they're very willing to help. I had an EP-1140 that I used for a while and still have the software for it, but I don't think it will do you any good.
There's really no need for anything fancy. Writing an EPROM is a simple task. The fancy stuff comes in handy for editing your bin files.
Old Nov 2, 2009 | 10:48 PM
tonymax2's Avatar
tonymax2
What do you mean by "custom chips only" ?
Old Nov 2, 2009 | 11:07 PM
tonymax2's Avatar
tonymax2
I've been prowling that 3rdgen site and others and am finding lots of interesting stuff. At the moment, I'd like to make a stock chip for my car and I'm getting the idea that with the correct .bin file, possibly from one site I ran into that has many files, I could burn a stock chip with just the programmer and its software. At this point I don't think I'll need an editor or calibration s-ware. Does that sound correct? Many thanks for the help.
To Generic chip for '89 PROM?
