Wiper Cam Arm '85
Old Oct 19, 2009 | 09:24 PM
grapidssteve's Avatar
grapidssteve
Default Wiper Cam Arm '85
Would having the cam arm on the wiper control module pointing in the wrong place give me the following issue:
Wipers work in low and high speed, but not in the delay. Also, wipers will not park until the key is turned off.
I've searched the topic and I have the factory service manual, but I'm not able to quite figure this one out. About all I see is that the cam arm is supposed to point to a hole in the board. I'm wondering if I may have it misaligned and that is giving me these symptoms.
I was having issues where they were working intermittently, but now have that solved by, I think, snugging up the inboard torx screw and cleaning the metal contact that goes from that screw hole to the control board. I think I'm moving forward on this wiper issue.
Thanks for any and all replies.
Steve
Old Oct 20, 2009 | 12:16 AM
cumbercr's Avatar
cumbercr
I had similar issues. I first thought I had a bad switch. Turned out to be the control module. I think its actually called the wiper motor control cover.
