tswade
Old Oct 20, 2009 | 04:14 PM
tswade's Avatar
tswade
1st Gear
Default tswade
any recommendations on raising C-4 about 1 1/2" front and rear
Old Oct 20, 2009 | 04:37 PM
STL94LT1's Avatar
STL94LT1
Why? Going four wheeling.
Old Oct 20, 2009 | 04:43 PM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
Only if the p/o had lowered it 1 1/2".
Old Oct 20, 2009 | 11:07 PM
Syclone354's Avatar
Syclone354
you could tighten the rear bolts on the ends of the springs, or get shorter bolts if you cant tighten them enough. On the front end you would have to put in shims either under the ends of the springs where they sit in the control arms, or shim in between the spring and the body of the car where the spring bolts up.
If you use this info to fit 26" wheels under a c4, id like to see pics when your done
To tswade
