Code# 42
Old Oct 22, 2009 | 05:31 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
Default Code# 42
can someone tell me what code 42 is, car started dieing on me so when I got home i checked it out.
Old Oct 22, 2009 | 05:37 PM
davidarnesen's Avatar
davidarnesen
electronic igniton controll grounded (never could spell sorry)
i had that on my 92 and i just pulled the battery for a few min and it went off hasent come back in a month or so.
could be a bad ecm or loose wire connection
Old Oct 22, 2009 | 05:41 PM
kimmer's Avatar
kimmer
got a 92 also, thanks ill check it out tommorrow, any suggestions where to start? also i just cut out the airbox could this have caused my car to die pertaining to the ecm?
Old Oct 22, 2009 | 06:14 PM
kimmer's Avatar
kimmer
ttt
Old Oct 22, 2009 | 06:52 PM
davidarnesen
no cuting the air box wont do anything to the ecm
Old Oct 23, 2009 | 03:13 PM
kimmer's Avatar
kimmer
where do i start looking?
Old Oct 23, 2009 | 03:31 PM
runner140*'s Avatar
runner140*
A search on the net "OBD 1 codes"..... a code 42 = electric spark timing circuit grounding. I don't have your FSM for a 1992. Check your codes in the FSM for a code 42.
Post a question....Don't have a FSM for a 1992....I have a DTC code 42???? Please help.
Old Oct 23, 2009 | 05:34 PM
kimmer's Avatar
kimmer
ok now it wont start at all could this be the ign. coil driver? I can do mechanicel work but my electrical is worthless, Im no good at testing voltage or probing things.
Old Oct 23, 2009 | 09:50 PM
josephf31's Avatar
josephf31
Default Est
could be just the connector under the hood making a bad (or no) connection, on my '91 it's tan/brown single wire with a connector right near the power brake booster.
Old Oct 23, 2009 | 11:27 PM
tblt44's Avatar
tblt44
Coil?????
Old Oct 23, 2009 | 11:48 PM
quickcat's Avatar
quickcat
The code is set by a lack of Electronic Spark Timing signal to the ECM. This is a white wire between the ECM and ignition coil driver(pin 12in the yellow or grey plug at ECM to pin B on the ignition module). Check your wiring between your ECM and ignition module including a close check of the connectors. The wiring is likely good but if you have had a connector gasket fail there could be corrosion in the connector causing a failure.
You could also have a short between the high and low resolution lines from the Optispark. This also could be a wiring/connector issue or a failed Optispark. It is hard to say.
This may be a simple problem that is difficule to track down. A factory service manual would be worth a lot to you at this point.
Matt
To Code# 42
