ground points on 92
Old Oct 22, 2009 | 11:30 PM
92LRC's Avatar
92LRC
Default ground points on 92
where are the grounding points or the electrical system on a 92 LT1 Vert?
I may have a grounding issue and I need to know where to start looking. I just moved and still have alot of things in boxes, including my FSM.
Old Oct 23, 2009 | 01:46 AM
383vett's Avatar
383vett
The negative battery terminal, chassis, or block will give you a good ground. Make sure there is a ground strap from the block to the chassis (on an 84 it's on the driver's side of the block.
Old Oct 23, 2009 | 09:22 AM
jonzcustomshop's Avatar
jonzcustomshop
I am getting the dreaded intermittent digital speedo in my '90, someone mentioned that if that was the case it is probably a grounding issue.
Are these points that you (383vette) mentioned the ones I should look to fix, or would it be a ground in the dash, or cluster itself?
Old Oct 23, 2009 | 09:01 PM
jhammons01's Avatar
jhammons01
If it is in the Cluster, I'm not sure what year they changed the Atari cluster...but if you have the old style...the back lights are going out??
If so, Go to Batee.com.....fish around as it is a guys personal website...but on it he has the very best step by step DIY for fixing the cluster.
Don't short cut...follow him step by step and you'll be fine.
Old Oct 23, 2009 | 09:13 PM
jonzcustomshop
as far as I could tell baytee only goes up to 89, the 90 and up just has a lcd screen for mph, fuel, and odometer, the rest are guages
To ground points on 92
