I Need An Opinion
Old Oct 23, 2009 | 02:57 AM
$Im2Fast4You's Avatar
$Im2Fast4You
4th Gear
Default I Need An Opinion
Which Spark Plughs Are Best For My 89
Old Oct 23, 2009 | 09:54 AM
SEARAY290's Avatar
SEARAY290
Cruising
Get the Ac Rapidfire. I have tried The Bosch-engine just didnt like them. I have used the Bosch with great success in my old Alfa Romeo and MG's. In My boat and other GM powered stuff-AC only.
Old Oct 23, 2009 | 02:57 PM
missinganova's Avatar
missinganova
stock engine with stock heads?
Old Oct 23, 2009 | 05:28 PM
wolverine1967's Avatar
wolverine1967
I just put in the E3 plugs on my LT1 and it starts up faster and runs smoother then with the previous delco plugs. milleage improved slightly and haven't had it dynoed to see if they made a difference in HP.
Old Oct 23, 2009 | 09:08 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Ngk tr55
Old Oct 23, 2009 | 09:49 PM
floridamale's Avatar
floridamale
AC plugs work OEM
Old Oct 24, 2009 | 12:48 PM
CFI-EFI's Avatar
CFI-EFI
The cheapest!
Any plug that is the correct configuration, thread size, thread length (reach) seat type, and of a proper heat range will work equally well. Once it sparks, it has done it's job. Don't look for miracles in a $2.00 to $10.00 part. The advantage of the exotic metal plugs, is plug life. If you are paying for the R&R, expensive plugs may be cost effective. Personally, I cannot leave any plug in my engine long enough, even if it is just to pull them out to take a look, to justify the expense of the exotic metal plugs.
RACE ON!!!
Old Oct 24, 2009 | 12:49 PM
Pete K's Avatar
Pete K
Originally Posted by CFI-EFI
The cheapest!
RACE ON!!!
Amen brutha.
Old Oct 24, 2009 | 03:24 PM
WW7's Avatar
WW7
I agree with CFI-EFI , I have tried different brands and guess which ones I have found to do the best job?? The same ones that came in the car from the factory, good old AC Delco standard plugs...Who would have known?..WW
Old Oct 24, 2009 | 05:26 PM
surfer92's Avatar
surfer92
He said the cheapest and I agree with that!!
To I Need An Opinion
