Knock Sensor ?? car is slow...
Old Oct 24, 2009 | 03:21 PM
1990 Rudy's Avatar
1990 Rudy
Default Knock Sensor ?? car is slow...
I know a 1990 convert is not a killer speed demon. I am just not getting what i use to get of it. Somrtimes it runs great then it warms up and is slow.
So I unhooked the KNOCK SENSOR and i got a SES light and it was really a dog...Pluged it in and it is better. I also saw that it looked like the sensor connector was not kinda broke?
i am also thinking Dist Cap and Rotor... and FUEL FILTER.
If you can help i would appreciate it ?
THANKS,
Steve
Old Oct 24, 2009 | 06:40 PM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
1990 Rudy,
if it runs worse after warming-up, it could be the cooling system thermostat (too cold or too hot -- believe your year should be using a 195 degree F thermostat) or it could be the O2 sensors and/or a bad plug or wire (or two).
Once the engine warms up, it usually goes into 'closed loop' (i.e. O2 sensors are used by computer to help control fuel injection) -- if the O2 sensors are reporting a rich condition when it's either ok or lean, then it would cause the PCM to lean out the mixture, possibly effecting performance.
THe above can be made worse when a bad plug or wire (or two) exist as that cylinder will dump raw fuel causing the O2's to really sense a rich condition, when the other cylinders are ok...
Old Oct 24, 2009 | 07:38 PM
1990 Rudy's Avatar
1990 Rudy
It has not thrown any codes.. The SES light was on but only when i unpluged the KNOCK SENSOR. It runs good and does not miss. ?
Old Oct 25, 2009 | 08:34 PM
91 corvette's Avatar
91 corvette
When mine was bad the ses light would come on,then my vette would not pull itself out of a mud hole.NO POWER!
Old Oct 25, 2009 | 08:47 PM
1990 Rudy's Avatar
1990 Rudy
It has to be something else. Any ideas out there ?
Old Oct 26, 2009 | 11:01 PM
Benny771's Avatar
Benny771
Well, I had an issue with my TPS and IAC. It was not set and worn.
I had start probs, sluggish at WOT, Hesitated, Just didnt run right at all.
Set all 3 and now its much better but im still waiting on a new TPS then i will reset and go!
Old Oct 27, 2009 | 12:55 AM
mtwoolford's Avatar
mtwoolford
do a good comprehsive tune up. plugs, plug wires, rotor, rotor cap, air filter, fuel filter, oil and oil filter. Do this first, then worry about everything else.
To Knock Sensor ?? car is slow...
