engine label adhesive?
Old Oct 25, 2009 | 07:59 PM
pmihaltian's Avatar
pmihaltian
Slingshot
Default engine label adhesive?
What adhesive cement or glue is best to use to afix the EPA, belt routing and other miscellaneous engine compartment labels? Mine are coming off and I want to re-glue them with something that will work well and not make a mess.
Old Oct 26, 2009 | 05:43 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
I use Elmers white, don't use too much, just a dab will do it!
Old Oct 27, 2009 | 12:05 PM
pmihaltian's Avatar
pmihaltian
Slingshot
Elmers on plastic and metal? Are you sure this works well for you in the hot engine bay?
To engine label adhesive?
