1990 fuel filter change
Old Oct 30, 2009 | 04:37 PM
lovmy90vette's Avatar
lovmy90vette
Default 1990 fuel filter change
Any advice out there for changing the fuel filter on a 90 vette? I suspect with 21K miles (bought it a year ago), the original is still in the car.
Old Oct 30, 2009 | 04:43 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
Use line wrenches.
Old Oct 30, 2009 | 07:10 PM
94vettelover2's Avatar
94vettelover2
Originally Posted by Paul Ruggeri
Use line wrenches.
Or use flared nut crows feet with extension.
Old Oct 30, 2009 | 07:45 PM
impact1968's Avatar
impact1968
If they've been butchered by the previous owner use vise grips.
Old Oct 30, 2009 | 07:50 PM
Joe C's Avatar
Joe C
#1 thing - get a GM/delco filter and not some "made in china" crap! pretty easy on the 90 - i changed mine last summer. since i was installing a new exhaust, i didn't have to deal with the front y-pipe. seems to me i had to remove the passenger side heat shield between the exhaust and filter. there is a clamp securing the filter to the frame and its held on with, i think, a 10mm bolt. can't really remember the wrench size on the fuel lines, but i'm guessing 14 or 15mm. you'll find out when you get in there. ditto on the hex fittings on the filter... only other thing is to orient it in the right direction - sorta like the "green side up" thing - fuel filters on the early c4 are a snap - i've done both the 85 and 90 model years - my understanding is its not quite a simple task on the later LT1 models - ??? good luck - remember, half the fun in owning these care is wrenchin' on these cars!
To 1990 fuel filter change
