Valve Cover Gaskets - 85
Old Oct 31, 2009 | 03:38 PM
golfkng's Avatar
golfkng
Default Valve Cover Gaskets - 85
Have a few threads on gaskets but am wondering what are the best to use on my 1985. Ecklers have a set listed at $24 - has anyone used them? Do you install dry or with RTV? Have read posts where some put RTV on heads and not on valve cover, others have put RTV on valve covers and not heads, some RTV just on the bolts, still others have used rubber gaskets. Kind of at a loss here with all the different ways they say to install.
Also has anyone used valve cover hold down tabs - they say that it distributes bolt load so you get a better seal?
http://www2.partstrain.com/store/det...L/T374993.html
Old Oct 31, 2009 | 03:53 PM
nutz4c4's Avatar
nutz4c4
FelPro Permadry VS12869T Advance Auto. Install dry and forget about them
Old Nov 1, 2009 | 08:18 AM
Chatman's Avatar
Chatman
I installed a set and am having trouble on one side. If I were to do it over again, and I might have to, I would use a little something to coat the surface first. Maybe something like Hylomar.
Old Nov 1, 2009 | 08:29 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
You can also get them at Autozone or NAPA. Valve cover gaskets should never have silicone or any other gasket goop put on them. I use RTV on the china wall, the 4 corners of the block/main cap seam, and maybe a verythin skin on the intake side of the heads but only enough to hold the gaskets in place during assembly. My garage floor is dry.
Old Nov 1, 2009 | 08:38 AM
floridamale's Avatar
floridamale
Old Nov 1, 2009 | 02:00 PM
Chatman's Avatar
Chatman
So, one school is I don't have a problem so you won't.
It's up to you of course but my suggestion would in no way cause harm and might save you needing to redo the project. When that also means replacing the crimp ring, or risking a crack in the old egr tube, it is something to think about.
Old Nov 1, 2009 | 02:06 PM
383vett's Avatar
383vett
I always glue mine onto the valve cover with rtv. If I ever need to pop the covers off, the gasket can be reused because it stays on the valve cover and doesn't tear. Works for me.
Old Nov 1, 2009 | 11:20 PM
86PACER's Avatar
86PACER
Those Permadry's are the only ones I use on any car I work on unless Fel-Pro doesn't make them for the application. These are very reliable gaskets.
Old Nov 2, 2009 | 09:01 AM
mazdaverx7's Avatar
mazdaverx7
^^thats great to know! i'll be picking up a set for the 84. i've heard good things about those permadry's!
To Valve Cover Gaskets - 85
