l98 headers on a lt1 i need a diffrnt answer
Old Nov 1, 2009 | 12:26 PM
rweasterly's Avatar
rweasterly
Default l98 headers on a lt1 i need a diffrnt answer
i have search the post about l98 headers on an lt1...first let me narrow my question down.....i dont care about emissions,clearance..etc...i just want to know if the d-port/square port is an issue???? i have l98 headers on my 77 c3 350 and i am installing a 92 lt1 in it soon...just want to know about the port design and can i use them without a performance issue.....once again just the square port vs the d-port info is all i need thanks
Old Nov 1, 2009 | 01:09 PM
pologreen1's Avatar
pologreen1
as long as the headers actually match and seal. Is there enough material to port them to match closer?
Old Nov 1, 2009 | 03:26 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
They will bolt on yes, but if the headers are D-port and the heads are square then you would be restricting flow. If the heads are d-port then I dont see any issues.
Old Nov 1, 2009 | 06:42 PM
rweasterly's Avatar
rweasterly
ok,so th SHORT answer is if i have l98 headers and i do(as in opening description above)...is they will work for my application...thanks
Old Nov 1, 2009 | 07:04 PM
pologreen1's Avatar
pologreen1
yes they might fit, but the point of headers is more air flow, unless you are dumping the car.
Old Nov 1, 2009 | 07:37 PM
rweasterly's Avatar
rweasterly
dumping the car???
Old Nov 1, 2009 | 07:43 PM
Guitarguy's Avatar
Guitarguy
i put l98 headers on my 92 no problems i use percys alum. gaskets.
To l98 headers on a lt1 i need a diffrnt answer
