tire pressure sensor
Old Nov 2, 2009 | 11:11 AM
utah lee's Avatar
utah lee
1st Gear
Default tire pressure sensor
The local chevy dealer broke the right rear tire pressure sensor on my 1994 corvette while repairing a leak. He has tried numerous used sensors with no luck. Apparently this part is no longer available new.
Any ideas? The owners manual says you can see your dealer to have the system turned off. Has anyone had any experience with this? My dealer says they don't know how. Please Help!!! The service LTPWS system light drives me nuts. Again . . HELP!
Old Nov 2, 2009 | 11:40 AM
STL94LT1's Avatar
STL94LT1
You probably need a Tech I to disable the LTPWS system.
Old Nov 2, 2009 | 01:20 PM
ddahlgren's Avatar
ddahlgren
on a 91 if you remove all of them it will not set any lights or codes... If that helps at all.. Did you try all the usual places that advertize here for a good used one??
Dave
Old Nov 2, 2009 | 03:45 PM
Wathen1955's Avatar
Wathen1955
I would like to know as well, as I had my rear tire repaired and the sensor broke, but the mechanic was able to fix it. I can see why they can break. When removing the tire with the machine, it has a tendency to place a lot of downward pressure on braking the tire from the bead. My sensor just happened to be placed couple of inches from the edge of the rim.
Old Nov 2, 2009 | 04:36 PM
Red Dwarf's Avatar
Red Dwarf
Whole bunch of info here;
http://forums.corvetteforum.com/sear...rchid=13174627
Try it again
Old Nov 2, 2009 | 05:01 PM
STL94LT1's Avatar
STL94LT1
Originally Posted by Red Dwarf
"Sorry - no matches. Please try some different terms".
Old Nov 2, 2009 | 08:11 PM
Red Dwarf's Avatar
Red Dwarf
Try it again!
Old Nov 2, 2009 | 08:22 PM
STL94LT1's Avatar
STL94LT1
Old Nov 2, 2009 | 10:56 PM
Wathen1955's Avatar
Wathen1955
Ditto!
Old Nov 3, 2009 | 11:22 AM
Red Dwarf's Avatar
Red Dwarf
Originally Posted by Wathen1955
Ditto!
The link works initially & then "blotto".....
Utah Lee,
Go to search look under....LTPWS".
To tire pressure sensor
