Timing Marker for New MSD Opti
Old Nov 3, 2009 | 04:25 AM
carguy604's Avatar
carguy604
Default Timing Marker for New MSD Opti
Has anyone ever made a timing marker to go with their MSD Opti? If so, how did you do it & where did you mount it? (Pics anyone?)
Old Nov 3, 2009 | 07:14 AM
jwt1603's Avatar
jwt1603
Timing marker for an Opti???
Old Nov 3, 2009 | 08:25 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
The MSD has a fancy screw to change the initial timing. Guess he wants to try different settings or check the factory setting.
Old Nov 3, 2009 | 09:01 AM
timmy 93's Avatar
timmy 93
I thought about it but mine failed after 650mi. dtc36 with a check engine light.I'm going to see how good the warranty is. Tim
Old Nov 3, 2009 | 09:14 AM
jwt1603's Avatar
jwt1603
Duh, I forgot about that. When I put mine in I asked MSD about that and they really, really suggested leaving it alone. They said it was too easy to get way out of whack with it. Of course I asked why bother with putting it on there then? Because some people wanted it.
I think I'm going to convert to that new system from EFI Connection where they dump the opti and the LT computer and switch it over to an LSx computer and coil packs.
Old Nov 3, 2009 | 07:23 PM
turbotim23's Avatar
turbotim23
hi I was told by MSD you can only change timing after 3000 rpm, That computer handles everything before that.So if you wanted a marker it would have to be timing tape,a homemade pointer at T.D.C and you would have to find exact T.D.C. I think the only way to put timing tape on our cars is to buy a underdrive system,some of those use a new crank pulley that mounts where harmonic balancer goes stock and then balancer gets bolted on top of that. Since you don't run belt around balancer anymore you could put timing tape around it instead.You'd then have to run it to 3000 rpm check timing then add a degree of timing at a time testing for spark knock after raising it each time. I wouldn't be afraid of adding a degree or two of timing to it with testing. If you were racing I'm sure you could make more power this way. Good Luck Tim
Old Nov 4, 2009 | 09:29 AM
rickneworleansla's Avatar
rickneworleansla
Most people that have tried to mess with the timing screw say it does not work correctly.
Maybe this is why.
Old Nov 4, 2009 | 10:06 AM
jimg's'93's Avatar
jimg's'93
I've seen that timing screw on the MSD. How easy is it to even access once you've buttoned the whole install up?
Old Nov 4, 2009 | 07:08 PM
RichS's Avatar
RichS
Pretty easy with a long screwdriver.
Old Nov 4, 2009 | 07:48 PM
calvette 11's Avatar
calvette 11
Default msd
With the timing cover off bring the engine to tdc.Replace the cover
Put the tape on the damper. make you a pointer.However I was told by msd to bring the rpm's to 3000.Adjust the screw to add advance.However the computer will look at it and might take the out advance at wot.I left it alone
Old Nov 4, 2009 | 11:42 PM
eguyett1985's Avatar
eguyett1985
I really don't understand what the reasoning for that screw is anyway. You can make far better timing adjustments in the tune.
Old Nov 5, 2009 | 03:46 AM
jimg's'93's Avatar
jimg's'93
Old Nov 5, 2009 | 05:38 AM
carguy604's Avatar
carguy604
Thanks guys... as a result of your feedback, I think I'll just leave it alone!
Old Nov 5, 2009 | 03:28 PM
turbotim23's Avatar
turbotim23
You can find tdc without taking the timing cover off and the computer will only take timing away below 3000 rpm.You can make no timing adjustments stock anyway[except using something like tunnercat etc.]. This is to give more horse power by adding more total timing above 3000 rpm. It is not something most streetcars would need but it would make more horse power in a race car maybe quite a lot if you try different fuels.
Old Nov 5, 2009 | 07:28 PM
t384's Avatar
t384
Wouldn't a good scanner tell you what the timing is anyway?
To Timing Marker for New MSD Opti
