HV or STD oil pump (again)
Most reasons against are:
1. Too much volume will make pump recirculate extra volume and cause
oil foaming and heating.
2. Possible oil starvation on continuous hig rpms.
3. Premature distributor (or even cam) gear
4. HP loss
5. Both CompCams and Crane advise not to use HV pumps with their cams
And here is link to "myths" on Mellings site:
http://www.mellingselectperformance....lume-pumps.pdf
Now, I know that nobody will tell that their product is bad, but they also make std volume pumps at the same price as HV, so I don't see why would they lie.
And now, what is most important to me, what should I use, HV or STD?
This is what I'll use in bottom end:
- stock crank, repolished (so clearances might be a little higher, good for HV pump?)
- std/std main/rod bearings
- Canton RR oil pan (7qt)
- hyd roller cam
- ls lifters
Just my 2cents.
Good Luck.
Suffice it to say that in spite of what Melling claims, HV pumps eat distributor gears. All of the guys on other Forums, whose views I respect, agree.
Of course, as with all other things, it's your call.
Jake
West Point ROCKS! Nation's TOP COLLEGE per Forbes Magazine!! Graduation Day Parade 20 May 2010!!
