my heart sanked !
I pulled into the drive afterwork, was sitting in my car turning off my "change oil Light" and puttin air in the tires the tires so the lowtire light would go out..
I CRANK UP MY CAR TO CHECK IF ALL THE LIGHTS WERE OFF, THEY WERE, WHILE IDLING IT DIED,WOULD NOT START, CHKD FUEL PRESSURE,IT WAS OKAY,DID THE QUICK THING AND SPRAYED STARTER
FLUID INTO IT IT, CRANKED BRIEFLY BUT HAD SEVERE VALVE CLATTER..I IMEDIATELY TURND IT OFF....
WHAT HAPPENED ???? ANY IDEAS. 1996 LT1 150,000 MILES
The car needs three things.... air, fuel, and spark. Unless you are on the moon then you have air, and the fact that it started with an alternate source of fuel tells me that you have fire. So, you are missing the fuel part. I realize that you checked the pressure, but are your injectors pulsing? Noid light would help here. If they are not pulsing I'd start checking wiring and ecm. The ecm sends the signal to pulse after recieving a signal from the CCM. If its not getting the CCM signal most likely the starter enable relay is not working and it will not turn over either, not positive on that, I don't have the electrical diagram here to verify.
EDIT: Also, pull a couple plugs to see if they are fouled out. The starting fluid is much more pure than gas so if they were fouled it might start with the starter fluid, but not gas. Maybe that you are getting spark, but not enough to fully ignite the gas.
Steve
When one just dies like that, most likely an Electrical issue.
OP states that he over heated the car.......overheated and burned which wires in the process?
Picture a cooked wire housing dropping on something metallic and blowing a fuse in the process
He's from Umble Texas.....no not Humble....they don't use that "H" for some reason....it's just there for window dressing.
But who am I to say anything, I'm from Youston.....No no Houston. Only folks from elsewhere say Houston.
You need a gauge to check pressure as I found out the hard way.
Check codes and fuses if pump isn't working.
Also weak voltage will cause it not to start.
Computer has to have full twelve volts when cranking engine or it will not fire up.
Keep with it and do the common sense things first and keep asking for help.
That's one of the great things about this site.
Steve
Initial Crank Action:
If you then rotate the key to the start position (assuming the anti-theft system has not disabled the starter), the engine will rotate.
Once the oil pressure has reached 4 PSI, the oil pressure switch will close allowing the fuel pump to run. (Note that you should have a black oil pressure switch/sender. It is mounted behind the distributor on the driver’s side and if it is not black, it is suspect due to a run of bad units that stayed in the GM parts pipeline for some time).
The distributor will send a string of pulses to the ECM (Engine Control Module) in response to the engine being rotated by the starter. These pulses continue as long as the engine turns (both starting and running) and if they are not present, the engine will not run.
ECM Reaction:
If the ECM sees oil pressure greater than 4 PSI and the reference pulses from the distributor, it will energize the injector drivers which will begin pulsing the injectors on for 4 ms (milliseconds) periods. (In the L98, all injectors on one side of the engine fire at the same time followed by all injectors on the other side firing at the same time. On the LT-1, the injectors are fired individually at the appropriate time).
The ECM will also pull in the fuel pump relay in effect paralleling it electrically with the oil pressure switch. (If the fuel pump relay fails, you can still normally get the car to start and run unless you can’t make at least 4 PSI oil pressure. This is a “limp home mode” feature put in place to allow for a fuel pump relay failure).
Can fire thru the sparkplug wires be detected using a TEST LIGHT?
and 3 codes..po 300 , po 400 , p1133, dont know if these have anything to do with killin spark , but thats where im at right now.
Steve
ECM Reaction:
