Running very warm
Old Nov 7, 2009 | 05:02 PM
gramps42's Avatar
gramps42
Cruising
Default Running very warm
I just bought a 1996 with the LT4/manual trans. Never had a corvette before. On the highway it runs around 185-190 according to the gauge. In traffic temp goes higher and at traffic light it goes way up.I did let it idle at home to see if fans kicked on and they did.Not knowing anything I just put in a new 180 thermostat and water wetter, with results about the same. Is this normal? Thanks, Tom
Old Nov 7, 2009 | 05:09 PM
jimg's'93's Avatar
jimg's'93
Normal, yes on my '93. So long as the primary fan is kicking on at about 225. The fan should then turn off after a drop of about 5 degrees.
Old Nov 7, 2009 | 05:21 PM
aminnich's Avatar
aminnich
Watch your digital gauge. Fans should come on low speed at 227*F and kick into hi at 236*F. Also take a flashlight and look into the opening on thepass side top of the fan shroud to see if there is junk in front of your radiator.
Old Nov 7, 2009 | 06:40 PM
WW7's Avatar
WW7
By the way, Water Wetter doesn't work with antifreeze in the radiator, it only works with straight water..For anyone up north its a waste of money!!...WW
gramps42's Avatar
gramps42
Cruising
Default running warm
thank you, both fans are kicking in properly and there's no debris in front. Highway temp is okay. I appreciate the quick responses. I feel much better now. Thanks again. Tom
Old Nov 7, 2009 | 06:42 PM
gramps42's Avatar
gramps42
Cruising
Thank you, $10 down the drain so to speak.
To Running very warm
