I've got a 93 and the key switch is a little difficult to turn off and release with the release button. I kinda have to chiggle it. Can anything be done to lubricate it to make it work a little easier or will I create additional problems?
From: Everyone needs something to believe in, I believe I'll have another beer. Wisconsin
Pull airbag fuse, disconnect battery, remove airbag modual and airbag clockspring, lockplate, turnsiginal switch and the screw/pin that secures the key cylinder inthe column. un-plug the vat's conection at the base of the column, white and orange I think? snake out old snake in new from top. Re-assenble.
