Setting idle w/ cam and TB?
Old Nov 8, 2009 | 08:00 PM
DrEvil11417's Avatar
DrEvil11417
Default Setting idle w/ cam and TB?
My '87 has a mild cam and a 52mm throttle body
Idle surges when it's cold but it's nice and smooth when it's warmed up
I followed the idle setting procedure, no change.. what am i overlooking?
Old Nov 8, 2009 | 09:57 PM
96GS#007's Avatar
96GS#007
The idle rpm is controlled by the ECM which commands the pintle position in the IAC. You have to re-program the ECM in order to change it. All you're doing is messing up the minimum idle air.
Old Nov 15, 2009 | 09:41 AM
DrEvil11417
should i be able to set it so the idle steady at the stock idle speed even w/ the bigger cam?
Old Nov 15, 2009 | 09:50 AM
mseven's Avatar
mseven
I think that depends on the cam set-up and how it feels. I believe stock is around 550-650, might be a bit low I would probebly bump it up 100 rpm in the tune and set w/IAC cts. to around 40or so., and maybe even a tick more timing there as well.
Old Nov 15, 2009 | 02:11 PM
96GS#007's Avatar
96GS#007
How mild is the cam? Auto or manual transmission?
Old Nov 15, 2009 | 05:54 PM
joe3906's Avatar
joe3906
Normally when you install a cam you get a custom tune, did you? If not, might want to look into that.
To Setting idle w/ cam and TB?
