brake caliper bolt stuck/head sheared off
Old Nov 8, 2009 | 08:05 PM
fettsvette84's Avatar
fettsvette84
Default brake caliper bolt stuck/head sheared off
Has anybody had this problem on the lower bolt? There isn't room to get any tools in that area to get it out. I've put penetrating oil on it, but it doesn't make a difference.
Old Nov 9, 2009 | 10:30 AM
tomtom72's Avatar
tomtom72
St. Jude 15 Year Donor
Active Streak: 90 Days
St. Jude Donor '08 thru '26
The bolt head is not rounded off, right?
This is what I did on my 90 w/J55's.
If the head is intact you need a medium deep or a shallow socket in 1/2" drive. You have to use a breaker bar as it is the only thing that will fit. It takes some patience to position the socket just right so you can get the bar on the socket. I had the car up on stands about three or four clicks up from closed. It isn't gonna be a quick thing either. You'll be lucky to get enough swing to get maybe a 1/4 turn at a time, maybe less. It took me at least 15 minutes to get it loose enough to get it to the point that I could put a box wrench on it.
Old Nov 9, 2009 | 11:21 AM
toptechx6's Avatar
toptechx6
http://cgi.ebay.com/ebaymotors/1984-...Q5fAccessories
Old Nov 9, 2009 | 11:25 AM
WW7's Avatar
WW7
The reason the bolt will not move is probably because the person before you used the tread locker liquid for heavy bolts and the only way to get that stuff loose is to heat it with a torch. I don't recall how hot it has to get to release the bolt but it needs to get fairly hot...WW
Old Nov 9, 2009 | 12:10 PM
jhammons01's Avatar
jhammons01
How is this relevant?
Old Nov 9, 2009 | 03:04 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
I guess when you ruin your part, you gotta go where there are more same same parts
To brake caliper bolt stuck/head sheared off
