Service Engine Soon question
Old Nov 9, 2009 | 12:52 AM
bpdfs's Avatar
bpdfs
Default Service Engine Soon question
Was curious if the Brake Fluid container has a sensor on it that would through the Service Engine Soon light on for any reason? Basically I get the light on after drive for 20 miles or so.. It comes on and stays on.. I turn the car off for a while and the next day its off and if i drive it for about 20 miles it comes on again. I was checking everything today and noticed Brake fluid was leaking a little bit, But i was not sure if that can through the light on?
1993 40th
Old Nov 9, 2009 | 08:14 AM
toptechx6's Avatar
toptechx6
Low fluid level in the master cylinder could cause the red brake lamp or yellow ABS lamp to illuminate but not the SES. Use the link below to pull codes stored in the ECM, there should be a history code stored for the problem that is causing the SES light.
http://www.corvettephotographs.com/c4vettes/codes.htm
Old Nov 9, 2009 | 11:22 AM
bpdfs's Avatar
bpdfs
how do i get the codes? without taking it in?
Old Nov 9, 2009 | 11:25 AM
pr0zac's Avatar
pr0zac
paper clip it
Old Nov 9, 2009 | 01:29 PM
toptechx6's Avatar
toptechx6
Did you look at the link?
To Service Engine Soon question
