Autocross
Exactly how should you mark chalk on the side walls and how do you interpret what it is telling you about your tire pressure?
Art
In any case, you will probably get a better response asking this over in the Autocross/Road-Race section of the Forum.
What is done to the car? It will depend on your particular chassis, wheel, tire, and engine set up and to a great extent your driving style. Then you can get into humidity, track surface type and condition, et al.
As noted above chalking really only gets you in the ballpark. It's not exact.
And the autocross / roadrace section has a lot of info (not necessarily all good for your application) on tire pressures.
Art
To help answer your question, try 38psi on the front and 34psi on the rear. That should be a good sarting point. Now, your chalk, place marks on the tire, where the sidewall meets the tread, around the tire in several spots. A good reference on your Kumho's will be some triangles which point to the edge of the tread where it meets the sidewall. What you are looking for is how much the tire breaks over during cornering. If you break the tire over and remove the chalk, you should add air pressure. If you are not removing getting close to the chalk, you may need to remove air or drive harder. This is to get started, also an alignment can impact how your tires will react. If you are just starting, then go and get some good seat time.
Unfortunately due to slow recovery from knee surgery I am missing the Solo2 school this weekend. My expectations are to run two events in December, one with Cal Club (SCCA), and the other with Speed Ventures. Both will be at AutoClub Speedway in Fontana. Surface is asphalt with some up hill and down hill. I figure being a newbie, I can take advantage of the instructors and get some practice before the season starts next year.
My desire is to protect the car, apply what I have studied and perpare for some fun. to that end seals / gaskets have been replaced, new brakes with cooling ducts, new tires, new hoses, belts, plugs, wires, coolant, fuel regulator, starter and fluids. The car had new battery and clutch just before I bought her from a co-worker. Everything that wasn't replaced has been inspected or tested.
This weekend she gets a harness bar, 5 point, tow hook (future time trials with SV) and new headlights (nothing to do with racing).
Back to your original question, the post above on reading the chalk is pretty complete. I would add that different tires have different sidewall strength so it gets you started. You'll have to experiment and see where you (and the car) like the pressures to be. Another generic rule of thumb is to run a couple pounds less in the rear than the front. Again, this pressure differential varies from driver to driver and car to car.
I assume since the tires heat with each run, checking / adjusting pressure between runs makes sense? Of course I then need to understand what more or less air does to the car. Assume you run more pressure in the front to improve turn in and less in the rear to prevent the car from skating and oversteering unexpectedly?
http://www.tirerack.com/tires/tirete...jsp?techid=58&
