L98-no juice to fuel pump fuse
help, no feul pressure in 1990 L98. I changed out the pump and filter first, big mistake! i'm not getting any juice to the pump or the fuse in the panel. I cannot find the feul pump relay to check it out. Its not on the firewall or under the dash on either side. I'm tempted to c hange out the ecm. Does anyone know where the relay is?
FYI...Power to fuel pump/fuse goes through oil pressure switch on back of intake manifold on drivers side. Power is cut off if no oil pressure is seen within seconds. Just making sure you are aware of this little feature while troubleshooting.
John
John
The fuel pump fuse gets power from two places, the oil pressure switch which closes at 4 psi and the fuel pump relay contacts. The fuel pump relay coil is energized by the ECM for two seconds when the ign sw is in run or past that to crank. The relay coil will also get power if the ECM see pulses from the distributor. The relay is located on the firewall to the right of the brake booster on a bracket with two relays and it is the rear relay.
Sorry to resurect, but I've got a similar issue on my '96 LT4. There's no juice to any of the relays or the pump. I also don't hear the pump click on when I turn the ignition, nor do I get 12 volts to the pump when I turn the ignition.
Anyone know how to test if it's the oil pressure switch? The switch is independent of the gauge, correct?
Here is a link to a thread from other day which shows wire diagram
Good luck
http://forums.corvetteforum.com/c4-t...questions.html
According to diagram,put power(12v) to point A & try cranking engine to see if it starts.If it does not start keep 12v at point A & check for power at fuse.If power is at fuse check for power to pump.If there is power through fuse & no power to pump,there is a bad connection or broken wire between pump feed & fuse.This test is assuming fuel pump relay & relay signals are working properly.Also make sure fuse is good(fuel pump)& switch with another fuse even if fuse "appears" ok.
This forum has a lot of great guys with tons of knowledge!
Fuse panel?
Hi guys, after reading multiple forums and multiple troubleshooting times on the primary fuel pump circuit still not receiving power. I accidentally noticed that one side of my fuse was only 3.4 volts. Upon further inspection I found the fuse holder prongs were actually wider on one side like something was jammed in the prongs at one point. I can only imagine a multimeter lead? That widening was enough to prevent a good connection, preventing the primary two second start circuit. Hopefully this may help someone in the furure.
If you want to test the fuel pump circuit, you can force the pump to run by unplugging the oil pressure switch and jumpering the contacts in the connector together.
Fuel pump
Aloha Ray,
My issue was someone had widened the two prongs that holds the fuel pump relay fuse. When I hit a bump or something. The connection was lost at the fuse. It looked like someone jammed a probe between the fuse holder clamps and it widened up enough to make me check the entire fuel circuit wiring from battery to pump. It was a bear to find. Hope you get your vette on the road soon. My is down for a T56 upgrade 🤗
Good luck with your issue and let us know what it was
Aloha Ray,
V/r,
Karp
V/r,
Karp
On my 85, if you apply 12v to pin G on the aldl...it directly turns the fuel pump on...if the fuse is ok....I too had a problems with the pins in the fuel pump panel...too wide for a good connection.....also the bulkhead connector by the fuel pump in the rear can be a problem....
Fuel pump circuit though oil pressure switch
John I have a 1990 base coup I have replaced fuse, and relay under passenger side dash, I have replaced fuel pump I have 2 second initial pulse, confirmed with meter and heard when key is turned on. My oil sending switch only has 1 pin and plug only has 1 pin, replaced it any way. To the side I also a have another, what appears to be a sending unit screw into the same channel very hard to eye ball but it has mutable wires going into plug, looks like 3 wires, this is very hard to get to to remove the plug and the unit. If the plug has a clip it is on the bottom side and can't see, I will have to get all full creative to release the clip and eremove the plug to jump it to test. I just want to confirm that that is the right switch you are referring to and if have any magic instructions on how to remove plug and sensor . FYI when I went to parts store they showed another sensor with 3pins for my car which was about an inch longer and I think that is probably is the one I am looking now. Any clarification or validation of this would be greatly appreciated. Thank you for your attention to my delemma. Raypdq
Fuel pump circuit
Aloha Ray,
V/r,
Karp
V/r,
Karp
Aloha Ray,
V/r,
Karp
V/r,
Karp
I don't think your problem is with the oil sending unit....your car should pressurize to 36# for 2 sec when you turn the key on...you say you have verified this by meter and "hearing"...are you saying you hear the pump turn on at the gas tank? or the "click" of the relay?..
I don't know all you've done so far, but I think you should go back to basics....get a fsm 1st of all, it'll have all the diagrams you need. Secondly, for issues with the fuel pump, you should have a gauge taped on your windshield from the schrader valve...
Next, my question would be, did it work before you changed the fuel pump if that's what you did 1st....I'd recheck that wiring at the tank...I had a similar problem and there is a recent thread about it and these guys posted tons of wiring diagrams involving your problem....mine turned out to be dual....bad connection at the tank and not a good connection at the fuse panel....If I was good at navigation, I'd find that thread for you....good luck...
