I have a 92 corvette. I just replaced the transmission with a updated zf. also put a new clutch kit and flywheel in. been working fine for a few thousand miles. all of a sudden though i can barely get it into reverse when it is cold, then when it warms up it engages very easy. any ideas?
also mid travel of the clutch pedal going in it makes a noise like if you lightly touching you finger against a spinning fan. it only does this intermentinally. you guys are good help! thanks again!
The clutch is not releasing, try bleeding the system. It should not be leaking any. Did you change the pilot bushing/bearing in the crankshaft when you did the conversion? That might be the cause of the problem also.
I will have to check with the mechanic who did the work. unfourtunatly i dont have the garage space or knowledge to do this complex of work. but i am definately trying to learn slowly but surely. man dirtbikes are way easier to work on!
