bad optispark
Old Nov 14, 2009 | 04:42 PM
MP6's Avatar
MP6
Default bad optispark
i think i have a bad optispark because i have a consistent miss at 4k rpms and simply wont rev past it. i have read that it could be a bent rod or bearing in the opti casuing a wobble not making a complete connection. so if i buy the msd kit with the new coil and everything will that be a fix to the problem? Also i found receipts from the previous owner and it looks like we had replaced the opti twice within a year or so. any ideas what could be causing it to fail? it is a 1992 lt1.
thanks
Old Nov 14, 2009 | 09:42 PM
airplane50's Avatar
airplane50
You could be right that the rotor woble is causing the symtoms you mention. The best way to to diagnose the opti is to see if you have any codes (16 & 36 are the death blows to the opti). The opti will fail if it gets moisture from a leaking water pump or from washing the engine. Had the opti and water pump replaced in my 94 at a chevy dealer which failed within 7,000 miles. The bearing in the water pump was bad causing it to leak on the opti. Replaced with the MSD unit which is vented. Before you start taking things apart check for codes.
Old Nov 14, 2009 | 10:26 PM
MP6's Avatar
MP6
when you say check for codes are you reffering to causing the short under the dash to use the speedo as the read out? if so i did that and i had no codes show.
if i have a leaking water pump wouldnt it be pretty noticible or is it possible it would be a slow small drip?
thanks
Old Nov 15, 2009 | 12:43 AM
ol school's Avatar
ol school
thanks
i thought the 92 had a regular distributor..?
Old Nov 15, 2009 | 11:26 AM
skybolt31's Avatar
skybolt31
thanks
A leaking water pump is not always noticeable. On the LT1 however, you can reach your hand up underneath it and feel the weephole, if you have a drop of green fluid on your finger, then you know it is leaking.
Old Nov 15, 2009 | 11:36 AM
airplane50's Avatar
airplane50
Great idea on how to check for a leak. The seal or bearing the the waterpump shaft is what usually goes bad. It is really had to see even with a dentist mirror and light. Be careful checking when the water pump is hot which is usually when it is leaking.
Old Nov 15, 2009 | 11:49 AM
airplane50's Avatar
airplane50
thanks
Yes, you can check the codes using by shorting the pins of tha Data Link Connector under the dash. Have the directions for 94-96 however yours may be different.
The water pump leak could be noticeable or may only leak when you are driving if the bearing or seal is bad. You may not see a spot on your garage floor or driveway because the antifreeze is leaking into the opti.
Old Nov 15, 2009 | 02:52 PM
MP6's Avatar
MP6
What is the weephole?
Old Nov 15, 2009 | 03:34 PM
surfer92's Avatar
surfer92
The weephole, is a hole underneath the water pump and is for water that weeps past the seals inside the WP and unfortunately it is right over the opti, so when the seals starts to go, you get coolant pouring onto the opti.
And then bye-bye opti, so it is a good idea when you replace the opti that you put RTV around the opti and connect a hose to the WP, so that any coolant that comes out of the weephole, does not get onto the opti.
Old Nov 15, 2009 | 04:02 PM
TWISTERUP's Avatar
TWISTERUP
thanks
It's odd that the previous owner would have replaced the opti and not the water pump, but a coolant leak will kill a opti (past experience) and many of the optis on the market today are poor quality (may be why it's had 2 optis in a year)--I also know about poor quality optis from past experience.
A bad opti will usually set a high and/or low resolution code---basic things that can cause a miss under load would be spark plugs/wires and/ or bad opti cap or rotor. Plug wires don't like getting close to headers, if your car has them. Anyway just my 2 cents.
Old Nov 15, 2009 | 04:43 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Nope. 1992 was the first year for the LT1, so it has an OptiSpark distributor
Old Nov 20, 2009 | 12:14 AM
ol school's Avatar
ol school
thanks for that info, sometimes i wonder if that is good or bad , sure was easier working on the dist, when it was on the top ..
To bad optispark
