Can't open rear hatch!
Old Nov 14, 2009 | 11:52 PM
SPD KILS's Avatar
SPD KILS
Default Can't open rear hatch!
I have an 88 Vette and the rear glass won't open when the buttons are pushed. There is a click in the rear latch but is more quiet than normal. There is no emergency cable to pull. The bad part is, the car has a full roll cage so there is no way to crawl to the back.
Any ideas?
Old Nov 15, 2009 | 12:09 AM
gbrtng's Avatar
gbrtng
There is an emergency cable to pull - it's light aircraft cable and tucked under the carpet ahead of the latch. Dig around ...
Old Nov 15, 2009 | 12:15 AM
SPD KILS's Avatar
SPD KILS
There is no cable. It was removed along with hundreds of items to reduce weight a long time ago.
Old Nov 15, 2009 | 12:17 AM
-=Jeff=-'s Avatar
-=Jeff=-
you try pushing on the glass to open while pressing button?
otherwise not sure
Old Nov 15, 2009 | 12:21 AM
383vett's Avatar
383vett
That's what I would suggest. Push down on the hatch while another person hits the switch. Might free up the mechanism.
Old Nov 15, 2009 | 12:22 AM
383vett's Avatar
383vett
If that doesn't work, smash the rear hatch and now you can go with a lighter lexan piece.
Old Nov 15, 2009 | 12:40 AM
gbrtng's Avatar
gbrtng
OK, you said that and I didn't believe you - sorry. You said the solenoid is not as loud; check that the battery is fully charged and maybe start the engine to bring the system voltage up to full voltage.
Old Nov 15, 2009 | 02:49 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
I'm guessing your gonna crawl back there and pop the solenoid with a screwdriver.
I'm also guessing that the plastic trim was removed as one of those hunerd parts.
GL
Old Nov 15, 2009 | 06:16 AM
vette079's Avatar
vette079
Let someone push and hold down the release button while you push down the hatch slowly...
Old Nov 15, 2009 | 02:41 PM
SPD KILS's Avatar
SPD KILS
I tried to push on the glass, I have tried everything mentioned so far. It does have the plastic trim on the top but if you look straight back you can see the solenoid but can't reach it.
Old Nov 17, 2009 | 12:26 AM
JrRifleCoach
Time to remove that extra weight.
Or get a long screwdriver.
Without that pull cord, your blue, screwed & tatooed!
Old Nov 17, 2009 | 09:29 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Maybe a long screwdriver to manually release the hatch?
When you get it open put a new emergency cord on - it weighs what 5 oz??
Old Nov 17, 2009 | 11:11 AM
runner140*'s Avatar
runner140*
Screwdriver attached to a broom stick?
Old Sep 12, 2010 | 11:24 PM
oldalaskaman's Avatar
oldalaskaman
use a long extension with a 10 mm. socket to remove the solonoid, use the long screw driver to release the hatch, its not as hard as it sounds. cut the back half of the solonoid off , pull the guts out, go to pepboys and buy a universal electric door lock actuator for 12 dollars, leave the boot on it and insert it in where the old guts were, the rubber boot will keep it in because its very tight , put a screw in the actuator eye to move the lever, the 10mm screw that held the original still works, hook up electric, did this today, works perfect.
Old Sep 13, 2010 | 01:04 PM
thedudeman321's Avatar
thedudeman321
You took out a small nearly weightless cable to save weight, but left the trim pieces, wires, and heavy (by comparison) solenoid?
Without that cable, you're in for some innovation. Best of luck.
Old Sep 13, 2010 | 01:29 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Another thread resurrected from the dead.
Old Sep 13, 2010 | 01:36 PM
thedudeman321
Aww man, that one slipped by me :o
I wonder how he got it open (if he did...)
Old Sep 13, 2010 | 02:31 PM
Keystring's Avatar
Keystring
That's ok..
He's probably still trying to get it open!
Old Sep 13, 2010 | 03:58 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
Originally Posted by Keystring
That's ok..
To Can't open rear hatch!
