Frisbee? What is it?
Old Feb 27, 2002 | 04:58 PM
Greg Johnson's Avatar
Greg Johnson
Default Frisbee? What is it?
I see frisbee a lot and just wondering what it is.
Greg :confused:
Old Feb 27, 2002 | 06:10 PM
The Dude's Avatar
The Dude
Default Re: Frisbee? What is it? (Greg Johnson)
"Frisbee" is a trademark for a particular type of flying disk toy. Not all flying disk toys are Frisbees, but all Frisbees are flying disk toys. :lol:
Old Feb 27, 2002 | 06:24 PM
DON M's Avatar
DON M
It is a large metal plate behind the waterpump pulley. GM put it on to dampen the A/C compressor when it started and stopped. Our resident Guru Gordon Killebrew says it doesn't hurt to take it off and it is worth some HP. The amount is in question but every little bit helps.
(Gordon Killebrew worked at the Bowling Green plant and was responsible for production defect repairs and originated many of the service protocols in the GM manuals).
Old Feb 27, 2002 | 06:43 PM
David-F's Avatar
David-F
Default Re: Frisbee? What is it? (DON M)
It's to dappen compressor vibrations, and yes it can be removed but some vibrations may be felt there was a bulletin in 87 were they used a real heavy dampener to remove the dampener on 4+3 cars and install additional altenator braces to help reduce vibration problems with the dampener removed, the proble was that when the O/D kicked in you would get a belt chirp because the engine slowed down faster then the water pump pully could with the dampener on, but it is there for vibration dampening, was not a problem with the old Delco compressor.
David Fulcher
Old Feb 27, 2002 | 08:12 PM
mozot's Avatar
mozot
Default Re: Frisbee? What is it? (The Dude)
hahahahahah
To Frisbee? What is it?
