My 93 was ripped off and had the rear end trashed. Wondering if it's okay to install a Dana 36 with 3.73 gears instead of finding a replacement original? I've built Jeeps but am a novice at working on my vette. Appreciate feedback.
I own a 1993 Corvette with auto trans and purchased from Mid America Corvette their 373 in a Dana casing and I love it. First to second is fast. Must disable ASR when drive low speeds. 9-60 is quick
I had to purchase bigger fatter tire for more traction:
REAR
Pirelli P7000
Sport Tires“ZR” High Performance Rating
Size: 315 / 35 / R / 17”
FRONT
Pirelli Zero Nero
Sport Tires “ZR” High Performance Rating
Size: 255 / 45 / R / 17”
Want to know more email me fantasy8000@***.net
I did the job myself.....have photos to share...
I believe the OP found a "solution" over 4 1/2 years ago.
If you've still got the Pirelli P7000 you're certainly lacking for traction. I don't believe that's been available in a 315/35R17 for a very long time. Very long time!
Originally Posted by Fast Tiger
more traction:
REAR
Pirelli P7000
Yes, but if you have a 6 speed, you will have to change the driveshaft.
If you have a A4 and stock engine, you are not going to get any MPG and you will be running over 3k rpm's on the highway.
I am looking at gears also, my thoughts are you should do some research first, if you are looking to make it a stoplight warrior only, then get the gears, if it is your DD, then your wallet is going to stay a lot lighter.
driveshaft half shaft batwing speedo thats what you need to change if your going to make that choice but again you may as well find two because if you plan on driving it hard some times the 36 may not survive , they get a bad rap but i have one with 373 gears that survived a 700 hp dyno day , what kills them is the slaming when tire finds traction ..
95 - ZF-6 with 4.10 - Don't even crack 1900 at 70mph.
id put my auto up against any standard . they can be built to shift flawlesly and faster than any 6 speed . and mine is good for 800 hp the original trans for that car too . i love standard i would own nothing but im sure but my clutch leg is screwed.
