rear spring config..
Old Feb 28, 2002 | 09:39 AM
devilfish's Avatar
devilfish
Default rear spring config..
Can someone tell me how to set-up the rear spring with spacers etc..
I have a fe1 cope. Picture would be nice.
Old Feb 28, 2002 | 05:11 PM
devilfish's Avatar
devilfish
Default Re: rear spring config.. (devilfish)
I mean the spacer and insulator configuration on rear spring at the dana 36.
Old Feb 28, 2002 | 07:07 PM
h rocks's Avatar
h rocks
fish, depends on whether or not you want to lower the rear a bit. If you do, install all the shims and insulators below the spring. If you want stock ride height, put them above the spring. In any case, you need all of them to make up the overall distance between the two U shaped brackets that hold the spring on. If you don't already have the long bolts to lower (level) the rear to match the front, then you might have just enough to shims and spacers to do that by placing them under the spring.
Old Mar 1, 2002 | 08:02 AM
devilfish's Avatar
devilfish
so i cant do annything wrong with this? Its more up to me how to config it?
regards
Old Mar 1, 2002 | 12:33 PM
devilfish's Avatar
devilfish
have annyone done this?
Old Mar 1, 2002 | 05:35 PM
devilfish's Avatar
devilfish
can something happen if i change the spacer config to lower the rear?
To rear spring config..
