Squeaking from underneath the car???
Old Feb 28, 2002 | 03:34 PM
NUckINg FuTS's Avatar
NUckINg FuTS
Default Squeaking from underneath the car???
Here's a question for you all. There is this real annoying sound(s) coming from underneath my car. There is a squeaking and also a creaking. I notice it mostly when I hit dips in the road but its also there while driving in a straight line. Any idea where its coming from??? Suspension maybe :confused:
Mike
[Modified by NUckINg FuTS, 1:34 PM 2/28/2002]
Old Feb 28, 2002 | 03:39 PM
scorp508's Avatar
scorp508
If you bounce the car on your own can you hear it? From the front? From the back?
Old Feb 28, 2002 | 03:40 PM
vader86's Avatar
vader86
Default Re: (scorp508)
sounds like sway bar and/or bushings
Old Feb 28, 2002 | 04:09 PM
GlockLT4's Avatar
GlockLT4
Default Re: (vader86)
yup :yesnod:
Old Feb 28, 2002 | 04:59 PM
NUckINg FuTS
Yes, it sounds like its coming from the back. Thanks guys :)
Old Feb 28, 2002 | 05:04 PM
Dave's_88's Avatar
Dave's_88
Default Re: (NUckINg FuTS)
Check to see if your exhaust system is hitting metal (bracket, underside, etc.). I had the same problem...this was the reason.
Old Feb 28, 2002 | 07:43 PM
yoslambo1@cs.com's Avatar
yoslambo1@cs.com
Default Re: Squeaking from underneath the car??? (NUckINg FuTS)
IF YOU FIND THE PROBLEM LET ME KNOW.EVERY TIME I GO OVER A SPEED BUMP I HEAR THIS AWFUUL CREEK NOISE! :eek: :cuss I KNOW THERE IS NOTHING WRONG WITH MY CAR CAUSE ITS BEEN LIKE THAT FOR YEARS!GOOD LUCK FINDING THE PROBLEM. :cheers:
Old Feb 28, 2002 | 11:28 PM
Gregory VanLare's Avatar
Gregory VanLare
Drop the sway bar and grease the bushings! Solved it for me!
To Squeaking from underneath the car???
