Back-up Switch Question
Old Feb 28, 2002 | 08:34 PM
TomsZ06's Avatar
TomsZ06
Default Back-up Switch Question
I have a 92 6-speed which, I believe, needs a new back-up switch. I have already checked the fuse and also checked to see I am not getting 12 volts to each back-up light sockets. Have anyboby had experience replacing this switch and what would it take to replace on the 6-speed? I also understand the switch is mounted to the tranny? Yes?
Old Feb 28, 2002 | 08:43 PM
No Ordinary 91's Avatar
No Ordinary 91
Cruise-In III Veteran
Default Re: Back-up Switch Question (TomsLT1)
the switch is on the passanger side of the tranny I believe, I need to do mine too, so i'll be watching this thread for some pointers as well :jester :cheers:
Old Feb 28, 2002 | 09:08 PM
Crazy Canuck's Avatar
Crazy Canuck
I had the same problem on my '86 4+3. It turned out the switch was fine, it just wasn't screwed in all the way. It somehow loosened up a bit, and it only takes a foot hair to make the difference between working and not working.
Old Mar 1, 2002 | 07:02 PM
85vetteguy's Avatar
85vetteguy
Buy April Corvette Fever Mag.(If you don't get it already.) There is an article in there on how to replace the switch. Pg. 68. Good Luck, Guy
Old Mar 1, 2002 | 08:35 PM
6spd89's Avatar
6spd89
Cruise-In II Veteran
Default Re: Back-up Switch Question (85vetteguy)
I replaced mine,I had to remove the slave cyl. to get at it.It is a very tight spot. You need a large open end wrench,i think maybe3/4 or 7/8?
I can't remember for sure(sorry). I also had the exhaust down at the time
(u-joints).The switch is about $50 from jeff kopp. My lights had not worked
for the past 2 years and finally thought this would be a good time to fix it.
Here is the part num.from my 89---10159402 list$75.75,cost $48.16
total with shipping.
The number is 1-800-728-8267 and tell them you are a forum member.
Matt
Old Mar 1, 2002 | 10:28 PM
TomsZ06's Avatar
TomsZ06
Default Re: Back-up Switch Question (6spd.89)
Thanks for everyone's help. I will check out the switch before spending the $50.
To Back-up Switch Question
