4+3 4 speed overdrive???
Old Nov 29, 2009 | 09:15 PM
steelhorse37886's Avatar
steelhorse37886
Navigator
Default 4+3 4 speed overdrive???
I have a 1985 4 speed car with 56,000 miles. I'm looking for some information from you guys as to where my problem lies. Of course the car has the switch on the console to switch on the overdrive. I can switch it on but the car doesn't go into overdrive. When the switch is on the indicator light comes on and when I decellerate the drivetrain is free as it should be. In other words it seems the overdrive is working during decelleration but is not working while cruising down the highway. Any ideas??? Thanks in advance... Randall
Old Nov 29, 2009 | 09:36 PM
jhammons01's Avatar
jhammons01
I'm not sure if your '85 has a TV cable...but if so it could be out of adjustment....
But you are confusing me when you say "when I decelerate the drive-train is free as it should be" What do you mean "Free"?
Free as in the same as when you push in the clutch or do you mean it shifts into O/D?
Old Nov 29, 2009 | 09:53 PM
steelhorse37886
Navigator
Free as if you had the clutch pushed in...
Old Nov 29, 2009 | 10:07 PM
rodj's Avatar
rodj
The fact the light comes on shows the computer is "trying " to engage the O/d.
The fact it doesn't engage could be for many reasons.The O/d relay may be faulty , the wiring to relay then to trans may be broken or faulty or as has been in some cases the wire is not even connected to the trans
Old Nov 29, 2009 | 10:32 PM
jhammons01's Avatar
jhammons01
That's not good. Has it always done that?
With the 4x3, even in Overdrive, if you let off the gas, the motor should be dragging just as if you downshifted
Old Nov 30, 2009 | 10:37 PM
steelhorse37886
Navigator
Has since I've owned it
Old Nov 30, 2009 | 11:19 PM
rodj's Avatar
rodj
From some very old archives
"If the light comes on and the unit freewheels that means the overdrive is burned up. This is a common symptom. The clutches for the overdrive are slipping so it reverts to a direct mode with a freewheel condition since the sprag in the unit is not locked."
To 4+3 4 speed overdrive???
