Question about LT1 edit
Old Mar 1, 2002 | 05:18 AM
KLLRVET's Avatar
KLLRVET
Default Question about LT1 edit
Can you "tune" LT1 edit like DFI? In other words, can you use LT1 edit instead of stepping up to DFI?
TIA
Old Mar 1, 2002 | 10:31 AM
-=Jeff=-'s Avatar
-=Jeff=-
Default Re: Question about LT1 edit (KLLRVET)
Yes, but I don't believe you can not tune on the fly like DFI..
I believe you need to make the changes and then reload the flash before starting the car again.
I have not used it personally so I coud be totally wrong
Old Mar 3, 2002 | 12:37 AM
95Purple's Avatar
95Purple
Yes you have to make a change and then flash the memory with the engine off. You cant make a change on the fly.
To Question about LT1 edit
