coolant air beeld pipe bolts and seals
Old 12-06-2009, 09:05 AM
twcz71
twcz71's Avatar
Default coolant air bleed pipe bolts and seals
I am going back together with my 95 LT1 corvette. I wanted to replace the bolts and seals for the coolant air bleed pipe. I went to the local dealer and was told I had to order the entire assembly. Does anyone have any info on this?
Tom
Old 12-06-2009, 11:44 AM
94z07fx3
94z07fx3's Avatar
Are you speaking of the steam tube connecting the heads at the rear of the engine?
If so,
I'm not sure if this PN is still current. GMPartsdirect or ThePartsLadi would know for sure.
Old 12-06-2009, 01:47 PM
twcz71
twcz71's Avatar
that's exactly what I am talking about.
Old 12-06-2009, 02:50 PM
STL94LT1
STL94LT1's Avatar
I've reused mine several times without a leak.
Old 12-07-2009, 09:31 AM
twcz71
twcz71's Avatar
When I took the heads off, I found that the passenger side damaged. The bolt was stripped and the head was damaged. that is why I need new ones. Does anybody by chance have the part number for the bolt?
94z07fx3, that part number worked great, Thanks.
Tom
Old 12-07-2009, 10:18 AM
94z07fx3
94z07fx3's Avatar
Have your parts counter guy look up this
gm part number 12552974
That should be the bolts but no picture, sorry.
Be sure to order four of those washers BTW!
Old 12-07-2009, 09:37 PM
twcz71
twcz71's Avatar
Bye the way thanks all for your help. I did order 4 washers but the bolts have been discontinued and can only be ordered with the pipe assembly approx 90.00 or so.
Thanks again
Old 12-07-2009, 09:54 PM
94z07fx3
94z07fx3's Avatar
Give Jason a call at Vette2Vette.net
Telephone: 1-815-673-6200
Contact Email: parts@vette2vette.net
Glad to help out.
Old 12-07-2009, 10:24 PM
twcz71
twcz71's Avatar
Thanks again, I will give him a call in the morning.
To coolant air beeld pipe bolts and seals
Quick Reply: coolant air beeld pipe bolts and seals
