Electric Fan activation
Old Dec 8, 2009 | 11:48 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Originally Posted by Potential C4 owner
Ok, so the aux relay is on the fan shroud and I can see it no problem.The main fan relay is to the left of the battery all by itself and not mounted to the firewall correct?
Correct, it is mounted to the inside of the left front wheel well held in place by two plastic push pin rivets. You should be able to read the part number on it, but it will be upside-down.
