Electric Vacuum Pump
Old Dec 6, 2009 | 04:30 PM
calpbs's Avatar
calpbs
Default Electric Vacuum Pump
How many inches of Vacuum does/should an electric pump pull to actually make the brakes work well and or would one of those hydroboost units be a better option. Would the pump be more efficient with a vacuum can. Has anyone delt with this and what can or should I expect.
Old Dec 6, 2009 | 10:22 PM
383vett's Avatar
383vett
Some of the GM cars of the 80s or 90s came with electric vacuum pumps for the power brake booster. Might want to google it to see which years were involved. I bought one from ebay years ago and my winter project was to try to use this thing for an engine vacuum evacuator if it'll pull enough vacuum.
Old Dec 7, 2009 | 04:38 PM
vettef6's Avatar
vettef6
383vett, which pump did you buy and did it work???
Old Dec 7, 2009 | 10:53 PM
383vett's Avatar
383vett
It's still on under the workbench so I don't know how effective it will be. I need to test it's vacuum pull first to see if it's worth my time. It's been a few years and I don't even remember what car it was for. It might have been a 90's Caddy. I'll take a pic of the thing if I get a chance. Willie
Old Dec 7, 2009 | 11:09 PM
lltrevino's Avatar
lltrevino
I played with hydroboost, brakes work great, but need to get use to how touchy they are. Also, I think a hydroboost set up, in a C-4 would be a tight fit, FWIW.
Old Dec 7, 2009 | 11:10 PM
383vett's Avatar
383vett
Here are a couple of pics. The thing looks like the Starship Enterprise.
Old Dec 7, 2009 | 11:17 PM
turbopezz's Avatar
turbopezz
I set up a pump like 383Vett has pictured.It made the brakes work good in a Turbo Gn,also used a can.
Old Dec 8, 2009 | 12:12 AM
thetoy's Avatar
thetoy
I have a hydroboost system on my 89 corvette and love it. I autocross the car all the time.
Old Dec 8, 2009 | 10:34 AM
383vett's Avatar
383vett
I just checked on the vacuum pump shown in my earlier post. It is a unit made by Stainless Steel Brakes made for supplying vacuum for power brake applications. I went out last night and was surprised to find the unit pulled 23" of vacuum. I saw the same unit in Summit as part of a kit with fittings for $269.
Old Dec 8, 2009 | 10:52 AM
vettef6's Avatar
vettef6
I found the same kit on eBay for just under $195
Old Dec 8, 2009 | 01:47 PM
383vett's Avatar
383vett
I bought mine on ebay without a kit for $85. Came with 2 relays too. Well see how long it works.
To Electric Vacuum Pump
