External Balance Forged Cranks Exist!
Old Dec 9, 2009 | 04:51 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Default External Balance Forged Cranks Exist!
Well, despite the fact I've read/heard several people say ALL forged cranks are internal balance, they're not.
Scat sells their 1pc rear main seal 383 forged cranks in:
External rear/Internal front
Just thought I'd post this cause 1/2 hour AFTER I ordered a cast crank, I found this out.
I may not change/cancel my order for the Scat Cast crank and get a forged instead, but I'll probably sleep on it. FWIW, I'm trying to build for longevity (i.e., 100k mile motor)
Opinions?
530TQ/450HP 383 build (SLP/TPI intake) -- should turn out similar to this build:
http://www.superchevy.com/technical/...t_results.html
Old Dec 9, 2009 | 05:51 PM
383vett's Avatar
383vett
Sorry Gregg. I'm trying to understand what you are saying. You ordered a cast crank because you want and externally balanced crank and believed that all forged cranks were internally balanced? Now you've discovered that forged cranks are internally or externally balanced and...?
Old Dec 9, 2009 | 06:36 PM
rodj's Avatar
rodj
Had that same crank in my 383 for three years
Never seen you question availability of that crank config GP.
Only questions relating to int / ext balance
Old Dec 9, 2009 | 06:58 PM
GREGGPENN's Avatar
GREGGPENN
Correct. and... am now considering forged.
Old Dec 9, 2009 | 06:59 PM
Pete K's Avatar
Pete K
What is the price?
6 inch rods I assume?
Old Dec 9, 2009 | 07:01 PM
383vett's Avatar
383vett
Gregg, I would think whoever you bought the crank for would let you swap the cast for the forged and you would pay the difference plus shipping charges. Shouldn't be a problem if you decide to go that route.
GREGGPENN's Avatar
GREGGPENN
I think I've got a thread in here on cast vs forged. I'd have to look.
Though the Scat9000 is rated at 600hp (and presumably similar torque), I have to consider whether a forged will hold up better over time. Seems like factory are cast IIRC, so it's probably nothing I should consider,,,but if I did, now is better than later!
Old Dec 9, 2009 | 07:03 PM
GREGGPENN's Avatar
GREGGPENN
Originally Posted by Pete K
What is the price?
It comes in both 5.7 and 6 for the 3.75 stroke.
$565 is the first price I found.
I'm using Wiseco 5.7" 20cc pistons (1/16" rings) for 10.2 static, 8.3DCR
Old Dec 9, 2009 | 07:08 PM
GREGGPENN's Avatar
GREGGPENN
Actually, I put my order on hold until tomorrow. I'd have to cancel that order and get it somewhere else (because the place where I got a Scat9000 for $170 , doesn't carry the 5.7" forged Scat 1pc RMS)
Still doable with no cost for restock, etc...
Old Dec 9, 2009 | 07:30 PM
WW7's Avatar
WW7
Scat 9000 for small block is rated for 500hp. The one for BB is rated 600hp...WW
Old Dec 9, 2009 | 07:33 PM
Pete K's Avatar
Pete K
I made 597 ft lbs at the wheel, spraying the snot outta that cheap cast crank. They hold up pretty well.
Old Dec 9, 2009 | 07:37 PM
WW7's Avatar
WW7
Its good to know they won't blow up at 501 hp ..WW
Old Dec 9, 2009 | 07:39 PM
Pete K's Avatar
Pete K
Unless you get the one with the small air bubble
That would be a bad day.
Old Dec 9, 2009 | 07:41 PM
GREGGPENN's Avatar
GREGGPENN
Direct from scatcrankshaft sales: 600hp and 7200rpms is their rating.
Eagle cast is 500hp. And White Performance confirmed the Scat cast units are harder to drill into (for balancing) than Eagles.
So....I went with a Scat to get the strongest cast model. Now I know another level exists above that (where I can keep my DMF).
Corvette Chris's Avatar
Corvette Chris
Personally, I'd stick with the 9000 series crank. I don't seem to recall you mentioning spraying or boosting outrageous amounts on the bottom end. And with the TPI setup, its a safe bet you're not spinning it to 7500RPM.
Old Dec 9, 2009 | 07:44 PM
GREGGPENN's Avatar
GREGGPENN
Can forged be just as likely to have a flaw (and break)?
What about the strength of a cast iron SBC block. Is a cast steel crank as strong/stronger than the block. Unless you have a better block, would forged be overkill?
Old Dec 9, 2009 | 07:57 PM
Pete K's Avatar
Pete K
Not really. Because it is forged, the grain structure is more dense, and uniform.
To External Balance Forged Cranks Exist!
Old Dec 9, 2009 | 08:24 PM
WW7's Avatar
WW7
Sorry about that,didn't mean to give bad information, it looks like some of these sites need to get there information correct, here is what I was going off of as far a hp rating.....WW
http://www.pmeracing.com/scat/scatcast.htm
SCAT
9000 Series Nodular Crankshafts
All 9000 Series Crankshafts are manufactured from a new revolutionary Space Age 9000™ Series Material. This material was designed for high strength and fatigue resistance. 9000™ Series material is the strongest cast material available! 25% stronger than the standard cast iron, and 2 to 5 pounds per crank lighter than a stock crank. Estimated horsepower use is 500HP for small blocks and 600HP+ for big blocks.
Old Dec 10, 2009 | 11:56 AM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
I was given the option of having my balanced internal or external.
I went internal since I was going away from the DMF anyways and it puts less of a load on the bearings.
The shop I used had to switch to a Lunati crank, he couldn't get it to balance with the SCAT and the short 5.7 rods.
Old Dec 10, 2009 | 12:20 PM
Z51L9889's Avatar
Z51L9889
Given your stated goals and usage, I think that a forged crank will be a waste of money. The SCAT cast crank should be plenty strong for your application.
BTW -- I got your e-mails but I haven't had a chance to respond yet.
