Sys
Old Dec 12, 2009 | 01:26 PM
moljape's Avatar
moljape
5th Gear
Default Sys
'93 C4 (excellent condition) getting SYS message flashing 3x every 15 seconds right where fuel range indicator normally is. Any ideas?
Noticed today for first time..might have something to do with the fact I had to jump the battery this morning due to the fact I hadn't driven it in a while?
Old Dec 12, 2009 | 01:46 PM
94z07fx3's Avatar
94z07fx3
It could be a low battery...
Sys flashes when there is a stored code that relates to a feature that does not have its own warning light.
The way to know for sure is to read the codes.
Old Dec 12, 2009 | 01:52 PM
moljape's Avatar
moljape
5th Gear
Thanks-dumb question, does that mean get a diagnostic check from the dealer?
Old Dec 12, 2009 | 02:04 PM
aminnich's Avatar
aminnich
It means you probably need a new battery. SYS flashing means the CCM has detected a problem. Seems that 99% of the time it is a weak or defective battery.
Old Dec 12, 2009 | 03:04 PM
94z07fx3's Avatar
94z07fx3
But never pay someone to read your car's stored codes until you've exhausted the paperclip method.
http://www.corvettebuyers.com/c4vettes/codes.htm
Old Dec 13, 2009 | 09:38 PM
C4DC's Avatar
C4DC
St. Jude Donor '06
The 2 times I have had this happen since 02' it has been the battery.
Old Dec 13, 2009 | 10:28 PM
surfer92's Avatar
surfer92
Check water in battery(people never do this anymore) and charge battery w/terminals disconnected(connected terminals can burn up your ECM or other electronics), low charge can cause the SYS flashing and check the codes.
Old Dec 14, 2009 | 12:05 AM
94vettelover2's Avatar
94vettelover2
Use distilled water if low.Have local parts store clear code for you & if comes back on(sys light),use paperclip method & let us know the code that is stored.Like someone else said it may just be a low charge or bad battery
Old Dec 15, 2009 | 08:55 PM
ce_me_vette's Avatar
ce_me_vette
I had this problem recently when I accidently left the courtesy lights on overnight. I after getting a jump I also charged the battery and the "SYS" message went away. If you get this message after have charged the battery the battery is not able to hold a charge.
Old Dec 16, 2009 | 09:14 AM
runner140*'s Avatar
runner140*
It means you should stay as far as possible from the Dealer (stealer) and go to an auto parts store and have your battery load tested. Usually its free.
More than likely, you only need a new battery. Its an easy install. Do a search for "battery install".
To Sys
