Got a small leak in my 84 with automatic. Looks like its at the shift linkage where it goes into trans. Is there a gasket that needs to be replaced or would a can of stop leak work?
Any info/advice would be appreciated.
There is a metal clad seal in there.
KD and others make a tool that removes and re-installs the seal without much effort. $30 or so for the tool, $5 for the seal.
Hey twotone, does it leak all the time? I got an 84 auto also and it only leaks when I leave it sit. If you use it everday or every other day it does not leak at all. Mine I could not find so maybe thats where its leaking from.
I have a 84 as well. I took mine to the shop. We put it up on the lift and the first place that my mechanic went to was the shift linkage. It was wet but it was not leaking. Turns out it is my tansmission pump. It is leaking a little and when it runs down the wind from driving the car sends the fluid back towards the linkage. It will be going into the shop soon for a rebuild. They can fix the leak for $400 or rebuild for $800. As old as the car is and 84K on the OD I am going to spend the $800 to get it rebuilt. I just bought it in September and my wife and enjoy driving it so for my peace of mind I am going to get it rebuilt.
I wiped down the area arount the inkage and don't plan to drive it for a while so the wind will not be a factor. I'll try to pinopoint the leak and post it.
The shaft is available from the dealer,part #24210712. It should come with the seal.
The tool I dont know. Last time I had my seal changed, my mechanic just dropped the pan to do it. However it was at that time that we both noticed the shaft was kind of rough and pitted. Come spring, both the shaft and seal are going to be replace.
Oh,BTW. Thanks to Pete K for the part# for the shift shaft. I previously posted a thread about my seal leaking and he gave me the info.
