Time(ing) for a change
Old Dec 16, 2009 | 01:01 PM
69mako's Avatar
69mako
Default Time(ing) for a change
The vehicle: 1994 LT1 automatic trans coupe with 148,000 on the clock, no mods, just stock. Nothings broken, it’s just time to think about a new timing chain. I’ll be doing the swap myself. So my fellow gear heads and brothers in grease, tell me what you know and what chain set I should go with and any pit falls I should avoid.
Thanks!
Old Dec 16, 2009 | 01:16 PM
pr0zac's Avatar
pr0zac
a stock replacement mellings, cloyes or gm will be fine. all are good. i think that the mellings will be the least expensive.
Old Dec 18, 2009 | 09:35 AM
69mako's Avatar
69mako
Thanks for the input, I'll oder a Cloyes after the first of the year. I'll have a Feb project
Anyone else with pearls of wisdom?
Old Dec 18, 2009 | 09:45 AM
Muffin's Avatar
Muffin
Read your FSM very carefully. There are a lot of ways to do this job wrong none of which give good results.
Old Dec 18, 2009 | 10:04 AM
69mako's Avatar
69mako
Already on it, it makes for great late night reading
Old Dec 18, 2009 | 03:26 PM
94vettelover2's Avatar
94vettelover2
Thanks!
Sounds like it will also be time for Hot cam kit along with new opti,waterpump(electric),tune-up(wires,cap,rotor,plugs),ported intake-while its off,ported throttle body.TIME FOR SOME POWER?This is what I would doGet that wallet ready
Old Dec 28, 2009 | 11:26 AM
69mako's Avatar
69mako
Nope-I'm happy with what I have
It will be just a timing chain swap and engine clean up, maybe a new idler arm pully and belt too
Old Dec 31, 2009 | 09:03 AM
69mako's Avatar
69mako
Cloyes C3039 is what I'm going with. I'll also replace the idler pulley while I'm at the front of the motor
Old Dec 31, 2009 | 01:11 PM
ddahlgren's Avatar
ddahlgren
While 'you are there' can really wound your wallet..LOL..
I started with it would be nice to get a little more power and found a great buy on a set of heads.. No problem yet then the TPI will not bolt up to it well after some research end up in a group buy for a First, then realize the heads have raised exhaust ports with a LT1 style port so manifolds won't fit and LT1 manifolds I am told have a different pattern on flange than L98 Y pipe so now headers but only low cost ones are Hookers that fit a 91 chassis and LT1 heads at the same time. Finally it would be a shame to get in that deep and not change the cam and while you are there the timing chain etc.. all for what was going to be a 30-50 hp buff up LOL..
To Time(ing) for a change
