Rear seal question
Old Dec 17, 2009 | 10:08 PM
rogerdoger1993's Avatar
rogerdoger1993
Default Rear seal question
Does the oil pan have to be removed in order to remove the rear seal housing?
BTW its a 93 LT1
Old Dec 17, 2009 | 10:13 PM
Pete K's Avatar
Pete K
BTW its a 93 LT1
No. Just remove the transmission.
Old Dec 17, 2009 | 10:16 PM
rogerdoger1993
ok thanks
Old Dec 17, 2009 | 10:25 PM
tblt44's Avatar
tblt44
Are you sure you have a rear main seal leak?
Could it be coming from your intake or the back of your valve covers?
Old Dec 17, 2009 | 10:35 PM
rogerdoger1993
yes its a slow but sure leak. But it comes from behind the housing. And I just took out the rear main seal but there is another one behind the housing. And there appears to be to bolts that go through the oil pan. And It also seems that I do infact have to remove the oil pan to get the housing off.
Old Dec 17, 2009 | 10:41 PM
Pete K's Avatar
Pete K
That sucks. Normally the paper gasket behind the adapter doesn't leak, and levering out the old seal from the housing is sufficient.
You can loosen the bolts and lean down the rear of the pan, without totally removing it.
Old Dec 17, 2009 | 10:45 PM
rogerdoger1993
Yea I am starting to realize that Harley's such a pain after all.
To Rear seal question
