Oil leak 90
Old Dec 18, 2009 | 10:04 AM
Cfan's Avatar
Cfan
Cruising
Default Oil leak 90
I have a 90 with an oil leak that appears to be above the trans, close to the firewall. Possible coming from some sensors. The oil that hits the ground is old and sticky. Any ideas, pictures ect.. would be appreciated.
Old Dec 18, 2009 | 10:11 AM
Pete K's Avatar
Pete K
Intake gasket
Valve cover gasket
distributor gasket
oil pressure sending unit(s) or the tree they mount in.
Old Dec 18, 2009 | 12:17 PM
gbrtng's Avatar
gbrtng
OP sending unit behind the distributor. Snake a small mirror in there and look.
Old Dec 18, 2009 | 03:18 PM
Cfan's Avatar
Cfan
Cruising
Thanks, thats the way I was leaning. I will check it out when I get home this evening and let you know what I find.
Old Dec 18, 2009 | 04:35 PM
aklim's Avatar
aklim
Clean all with break cleaner and use dye.
To Oil leak 90
