Exhaust noise without Resonator
Old Dec 18, 2009 | 04:33 PM
therbst's Avatar
therbst
Default Exhaust noise without Resonator
I'm hoping that I can gather enough opinions to make a wise decision. I have a stock 95 LT1 except for dual magnaflow mufflers out the back (mufflers only). After getting the car out of storage I was looking to do some mild mods (intake, exhaust, maybe 1.6 rocker rollers). My first step is the exhaust. If I take out the resonator will that create a huge increase in the sound level inside? Not to worried about outside. The reason being is that until I save up enough to go with the long tube and high flow cats then back to the dual magnaflows, I'd like to at least take the resonator for now, just not sure what that will get me. any advice would be appreciated.
Old Dec 18, 2009 | 04:51 PM
96 lt-4's Avatar
96 lt-4
With the factory cats it won't be nearly as bad as aftermarket ones.
Magnaflow has a resonator with an X-pipe.
Old Dec 19, 2009 | 01:03 PM
therbst's Avatar
therbst
So if I replace th existing resonator with the xpipe MF resonator, the drone should go away!
To Exhaust noise without Resonator
