[B]In Head Sensor[/B]
Old Dec 19, 2009 | 01:28 PM
KayCee's Avatar
KayCee
Default [B]In Head Sensor[/B]
Can anyone on the forum tell me what are the sensors in the side of each cylinder head above the 1 & 3 plugs on the left and the 6 & 8 on the right on a 1995 C4 LT1?
Old Dec 19, 2009 | 02:55 PM
JAKE's Avatar
JAKE
Someone with a 95 Vette will have to chime in to be specific because GM just LOVES to change things. But on the 96, there is only a plug between 1 & 3 and the one of the other side of the engine, 6 & 8 is the coolant temperature sensor for the dash gauge. The CTS for the PCM is in the front of the water pump.
Jake
West Point ROCKS! Nation's TOP COLLEGE per Forbes Magazine!! Graduation Day Parade 20 May 2010!!!
Old Dec 19, 2009 | 04:24 PM
STL94LT1's Avatar
STL94LT1
Jake
It's the same on my 94, and I'm pretty sure the same on the 95 also.
Old Dec 22, 2009 | 11:46 PM
KayCee's Avatar
KayCee
Indeed, thanks. After going back to the old heads to look, one side is a plug and the other side is the sensor.
Thanks for the tip.
KC
To [B]In Head Sensor[/B]
