This is Cool...SLP Runner Mods
Old Mar 2, 2002 | 08:04 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Default This is Cool...SLP Runner Mods
This was posted a while back but I dont think the finished pictures were seen.Someone cut the back of the SLP runners open and cut the divider wall out and welded it back up.I just came across this on the thirdgen site and thought id post it here.
They didnt post any power numbers yet but looks like a cool way to get a poor mans superram IF the idea works.
On the page,some of the jpgs posted dont work,but go down to the bottom of the thread and youll see the 2 pics of it finished.
Tell me what you think...they did do a nice finish job,cant see the welds.Maybe this is how SLP shouldve made them in the first place.Their runners in stock form arent any better then the GM runners IMO.They need alot of porting to open them up to large tube size.
http://www.thirdgen.org/techbb2/show...threadid=46659
Old Mar 2, 2002 | 11:31 PM
BBA's Avatar
BBA
Default Re: This is Cool...SLP Runner Mods (Bill's86Coupe)
Those are some sweet looking runners..I'd love a pair done like that!
Old Mar 3, 2002 | 12:17 AM
Bill Reid's Avatar
Bill Reid
I have heard of this being done. I've also heard that there is a maximum limit of cutting out the divider... before you can actually start to LOSE horsepower. I believe I read this somewhere in the Engine Mods sections. Be careful... and perhaps post this in the Engine Mods section for feedback. :yesnod:
Old Mar 3, 2002 | 12:49 AM
Aggravated4life
Default Re: This is Cool...SLP Runner Mods (billreid1@***.net)
Hey BBA and BillR,
Thanks for the comments...I have SLP runners in storage that I began porting similar to what this person did...need to finish it up but havent been able to since last summer.
I cut the back wall off and knocked the divider out...however I left the divider nearly halfway to try and keep it close to the SR runner length without overporting.
I remember Ralph on the forum tried to siamese his SR tubes and said he lost some power so didnt want to go overkill in my case with the SLP's.I need to finish porting and cutting then weld the backs up and hope when done can flow alot more without sacrificing torque so much.
These SLP's need alot of work to flow real good and fill the engine better with more mass of air to change pressure in the manifold.
I agree this persons mods look nicely done but on a stock motor and cam,not sure if there will be any significant gains.The stock cam is designed around the stock runners and economy/emissions so Im sure if someone does this type of work they need at least a better cam and possibly head work.
Old Mar 3, 2002 | 01:05 AM
BBA's Avatar
BBA
I would think you should loose some bottom end power...in order to gain some up top. I see no down side to that as long as you have a cam that can use it ( IE: The stock L98 cam just doesn't have top end power in it's design ) and a free flowing exhaust.
Besides, my L98 makes so much torque you can break the rear tires loose just by going WOT in first even with the car moving already, I think I would want more top end power and less low rpm power as a rule. :D
To This is Cool...SLP Runner Mods
