Headlight and window problem on 94
Old Dec 19, 2009 | 11:42 PM
bluenotes's Avatar
bluenotes
7th Gear
Default Headlight and window problem on 94
My headlight motor keeps running on when it shuts or opens. The manual hand dial on the motor spins for about 10 seconds after opening or closing the light. Otherwise its fine.
My windows are starting to get out of alignment at the top when they close. Any advise on fixing this problem?
Old Dec 20, 2009 | 08:17 AM
runner140*'s Avatar
runner140*
On the headlight issue, sounds like you have a bushing problem. Its an easy and cheap fix. The bushing look like this:
The instructions are at the top of the page as a "sticky".
On the window issue, you will have to pull the door panel and adjust the window. Do a "search" for a how to.
